Truck broke down today...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by perfectsoldier23, Apr 16, 2016.
  1. Apr 17, 2016 at 2:24 PM
    #41
    docsg
    docsg Well-Known Member
    South Alabama
    2020 White TRD OR SBDC
    Raptor 4" oval rails, OEM door sill protectors, totally debadged, OEM mud guards, OEM bed mat, OEM S/S tail pipe extension, BDT tailgate letters, Weather Tech sun screen.
    Quote: I am lucky, my dealership has some very good techs that are certified and have gone to the new Toyota school on the 3.5L engine and 6 speed transmissions. Quote
    I am also very lucky. I bought my Tacoma from a dealership quite far from where I live. I took it to a large dealer (Montgomrey, AL) near where I live to check out the badly fitting rear door window seal. Lady service writer gave me the typical Toyota B/S "that's normal!" Just on a whim I stopped by another dealer (who is actually a little closer) in Enterprise, AL. A young man name John (certified tech who has won awards with Toyota) looked at the door seal and said "that's not right." They took pictures of the seal promptly ordered me a new one. I mentioned the transmission discussions on TW to the tech and he said he was well aware of them as he follows the forum. He said "just to be safe, can you leave it overnight with me and I will check your transmission and differential fluid levels and the torque setting on your rear springs as well as changing out the door seal." He feels that if a customer has a compliant or concern it is Toyota's obligation to check it out...regardless.
    whopper, TacoRD16, wmeyer116 and 14 others like this.
  2. Apr 17, 2016 at 2:41 PM
    #42
    Tacoma2GR
    Tacoma2GR Well-Known Member
    Hesperia, CA
    2020 TRD Sport 4x4
    I wish I could find a dealer like that in socal
    jasonct, jfornelli and James_Bond like this.
  3. Apr 17, 2016 at 2:54 PM
    #43
    transworldmoto
    transworldmoto Well-Known Member
    Ben
    California Coast
    2016 Access Cab TRD OR 4X4
    Yo're an idiot, your posts are useless, you troll almost every thread on this forum and you shouldn't be in the 3rd gen forum to begin with. Go ban yourself, troll.
  4. Apr 17, 2016 at 3:24 PM
    #44
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I don't own one because its a low quality, and poorly designed truck.
    Now if Toyota installs better engine and not a minivan knock off that downshifts anytime car in front of you farts, installs rear disc brakes not a Model T technology of 19th century, and removes ugly grill, improves quality, I may buy another Toyota Tacoma.
    Lets be clear here, Toyota needs me and people like more than We need Toyota. You know Great thing about market economy, is that, there is always competition. :D
    Your comment about transmission is funny. "Some people" ?
    its not like there is guy named Jose opening bottles to fill transmissions. its done by machine, in this case poorly setup machine. So if more than one vehicle has a problem, you can bet every vehicle that went through that line is under filled .
    Also your question about me getting banned I find disturbing.
    You either hate free speech (truth) or you are Toyota employee. I wonder which one is true..
  5. Apr 17, 2016 at 4:02 PM
    #45
    Launch21v
    Launch21v Well-Known Member
    Fontana, CA
    16 TRD sport dclb 4x4 tech pack w/jbl white
    Did someone just fart in here? I thought I heard something.
  6. Apr 17, 2016 at 4:35 PM
    #46
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Your post is awfully ignorant.
    I've known citizens who have had rear disk swaps on their Tacomas and recorded worse brake performance than when the truck was equipped with drums. The drum brake is not a failed design, it works well in fact, it's just old.
    And no, Toyota Corporate doesn't need you.
    There are a lot of factors that can cause an engine to go into Limp Mode. I don't recall the OP specifying which gear he was in when the fault occurred, however the fact remains that this is V6. Take the weight of the trailer, and likely circumstance that this was an onramp with an incline, being pulled by an "economy truck" (face it, the Tacoma isn't meant for towing) with a high-gear transmission and small displacement engine, and you are all surprised that the engine went into Limp Mode? If you are trying to pull a 5000Lb Trailer on an incline (keep in mind that towing specs are based on level ground) and trying to accelerate on valve-cycle-timing advancement, small displacement V6, you are going to create a fault.
    I'm willing to bet that the code was thrown by either the cam position sensor or the crankshaft position sensor; caused by the extreme engine load putting enough resistance on the drive train while the engine was trying advance cycle and timing and thus the DTC was thrown to prevent valve damage (contact with a piston).
    No, I don't work for Toyota.
  7. Apr 17, 2016 at 4:37 PM
    #47
    transworldmoto
    Ben
    California Coast
    Don't let him get to you, man. He does this shit on literally every thread he can. I just ignored and moved on. Only reason I even know it was BlewT is from your quote.
  8. Apr 17, 2016 at 4:42 PM
    #48
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Oh I don't, and I'm familiar with his grudge against the 3.5L in the new Tacoma. I just spent enough time in automotive school to know that what he has said is incorrect, and feel that others and himself should be made aware of that.
  9. Apr 17, 2016 at 6:24 PM
    #49
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    off topic,, is blue t is a crybaby in this dept?. .. I will give time for mother toytoa to fine tune this new engine 3.5 then it should be good as or par as 4.0. ok lets carry on
  10. Apr 17, 2016 at 8:43 PM
    #50
    dutchjim
    dutchjim Well-Known Member
    Jim
    San Diego
    because_wumbo-truck likes this.
  11. Apr 17, 2016 at 10:47 PM
    #51
    Vandy09
    Vandy09 Well-Known Member
    2016 Tacoma TRD offroad
    While I agree with a lot of things said this is false. There are a LOT that goes into a tow rating and it's not just based on level ground. You should look into it more. It's actually pretty impressive what all has to be passed at a weight to get to that rating
  12. Apr 18, 2016 at 5:39 AM
    #52
    western88
    western88 Chris b.
    ny countryside
    I did look thru all other topics for few hrs on what blue t saying and others. I had to weed out the trollers. True the 3rd gen product is not good as 2nd gen. Still going to have its own quirks which can be fix but still going to have some major issues which can be an ass drag.
    I can see the quality is getting bad on toytoa side and treatment of loyal customers is in the shits.
    From what i hearing about the 16 taco. I will not buy one until late 2018 if the company ever get right from many wrongs. My 14 taco is going to be the last one.
    BlueT likes this.
  13. Apr 18, 2016 at 10:36 AM
    #53
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    OP sorry that happened. The pic of the tow driver is priceless.
    I hope your truck gets figured out & the situation all works out for the best.
    Please post up what the dealer says to help others good luck
  14. Apr 18, 2016 at 10:54 AM
    #54
    Starfury2k
    Starfury2k Oh no not again...
    Drew
    FTPLA
    2016 Inferno TRD OR DCSB
    This is great info! I am going to be in Enterprise in late July, gonna look this guy up!
  15. Apr 18, 2016 at 10:58 AM
    #55
    docsg
    South Alabama
    I didn't own a 2nd gen Tacoma so I can't confirm your statement about the 2nd being better than the 3rd gen. So far I have had very few issues with my '16 SR5. The only problem (and it is really not one) is one rear door window seal does not fit properly and that will be corrected shortly. As I stated in my previous post, the tech offered to check the transmission, differential, and springs when he replaces the seal (only as a precaution not because of issues). Only inconvenience is having to leave it overnight until the transmission fluid reaches a certain temp. He said that Toyota has a tool that will measure transmission fluid at any temperature but he doesn't like its reliability. I have had 3 Tundras ('01, '05, '12) and never had to have a dealer do a thing to any of them. They were still "tight" up until the day I sold them. I would have kept the '12 Tundra a little longer as it only had 45K on the "clock" but I hit a mail box and badly scratched the side and that was it for that truck! Plus, the '12 was just too f****** big for me. All I can say is get in a Chevy or Ford truck with 50K+ miles and see if it is still tight....
  16. Apr 18, 2016 at 11:01 AM
    #56
    docsg
    South Alabama
    You will like him! He's checking out my truck next week and I'll show him your post. He should get a kick out of that!
  17. Apr 18, 2016 at 11:18 AM
    #57
    Sam B
    Sam B Well-Known Member
    Samuel
    Poway, Ca.
    16 Red DCLB TRD Sport 4x2
    none
    Another douche bag added to the ignore list! "Toyota was still putting frames that were rusting badly through 2 generations and possibly this 3rd generation" Joining your Blue T buddy!!!!
  18. Apr 18, 2016 at 11:35 AM
    #58
    Starfury2k
    Drew
    FTPLA
    I am only going to be in town for work for a week, going to have to find a way to squeeze in a visit. My dealer here said they checked all that too, but it didn't take them as long as others have said it should to do all that. Call me paranoid if you want, but better safe than sorry.
  19. Apr 18, 2016 at 3:44 PM
    #59
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i bet it is a sensor issue...........IMO
  20. Apr 18, 2016 at 3:47 PM
    #60
    Kaerntner
    Kaerntner Well-Known Member
    2016 doublecab limited 4×4
    And,what did they find wrong??
