Truck Cab Rear Pressure Vent *Research Experiment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by csuviper, Nov 23, 2010.
  1. Jun 28, 2011 at 12:22 PM
    pinktaco808
    pinktaco808 Hot Steppa
    what about the standard cabs? there was a post or thread somewhere on here that someone made. Can someone post or find it thanks.
  2. Jul 16, 2014 at 8:36 PM
    Yota64
    Yota64 Professional Threadjacker
    Love seeing trial and error research like this. I know this is an old thread but what happened next?? Did putting foam/whatever on the entire back of the cab help?
  3. Jul 17, 2014 at 7:54 AM
    csuviper
    csuviper [OP] Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    Yep kept the foam in the vent. Noise was reduced a lot. There was a problem with pressure in the cab though. Had to only use heat and AC on recirculating mode or you would feel the pressure in your ears.
  4. Jul 17, 2014 at 8:48 AM
    Yota64
    Oh no, I was referring to one of the images in your first post. It looks like you put something black over the entirety of your cab wall?
  5. Jul 17, 2014 at 10:07 AM
    csuviper
    Brian
    Broomfield, CO
    Rammatt sound deadening material
  6. Jul 17, 2014 at 10:16 AM
    Aw9d
    Aw9d That one guy
    I don't have this vent on my 2011 DC. I thought I saw a vent somewhere when I did my sound deadening but I can't remember. I do know after sound deadening my doors do require more force to close with the windows up, which I like.
  7. Jul 17, 2014 at 10:39 AM
    Yota64
    Oh okay, cool! And how much did that affect the road noise?
  8. Jul 17, 2014 at 4:40 PM
    mshultz
    mshultz Well-Known Member
    Michael
    Wooster, Ohio
    Barcelona Red
    I could not see a vent on my 2014 standard cab, although the tool box makes it hard to see down there.
    There is a substantial difference in the amount of force it takes to close the doors if a window is left down.
  9. Feb 17, 2015 at 9:57 PM
    NotRed
    NotRed Well-Known Member
    I have a 2015 Access Cab and found it has the vent behind the seat. This weekend I stripped out the interior to install sound deadening material - had to take it home before job was done, so just re-installed the driver's seat for the trip. WOW! I know now where the road noise comes from. I guess it was more muted with the back seat panel installed as the sound would not be so localized, but driving on the freeway with a bare back wall the noise sounded like a window was half way down.
    I think the theory of needing a place for the air displaced by airbag deployment makes sense. If all six of them deployed it would cause a major pressure increase in the truck without having a means of expelling the excess.
    I think I may experiment with adding some type of foam pieces that will allow passage of air but deaden the noise coming in - kind of like designing a mini cab-air muffler system :notsure:
  10. Feb 19, 2015 at 9:56 PM
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
    I took all the plastic molding and stuff out from behind the seats in my 2014 double cab a few months ago and did not see a vent like that. I just left it as bare metal and didn't install any replacement sound dampening. Road noise is about 10 or 20% louder than before but it doesn't really bother me any - definitely worth it for the extra space.
    I have no idea what that vent is for but the airbag displacement theory makes sense.
  11. Feb 20, 2015 at 5:53 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    wow all this about a vent
  12. Feb 21, 2015 at 11:10 AM
    NotRed
    Well, after filling the vent with breathable foam, the noise of the air rushing trying to get out is louder than the road noise before. I have settled on putting MLV on the outside of the vent, and will line the inside with ensolite to hopefully dampen the incoming soundwaves.
  13. Feb 21, 2015 at 4:59 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    And Toyota put these things in because? Just about every thing on the road to day has the rear air vents and for good reason.
  14. May 23, 2015 at 4:19 PM
    wyomingblazer
    wyomingblazer Member
    Stan
    Cheyenne, WY
    2014 Access Cab SR5
    Did you try putting MLV on the outside of the vent and ensolite on the inside? How did that work? That is the same idea I have for my 2014 access cab.
  15. May 25, 2015 at 10:15 PM
    #35
    NotRed
    Seems to be marginally better but not as much as I had hoped.
  16. May 27, 2015 at 7:06 AM
    #36
    wyomingblazer
    Stan
    Cheyenne, WY
    2014 Access Cab SR5
    Do you think there is any possibility the vents could be damaged, or could have been incorrectly installed, in any way? I don't know if some people are more accepting of the noise or if their trucks are less noisey than other trucks. I don't understand why more people aren't complaining. I have noticed that it appears my truck is slightly less noisey if the air control is on recirculate.
  17. May 27, 2015 at 7:36 AM
    #37
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    primary reason cars have the vents. closing the doors without having to slam them super hard
  18. Jun 1, 2015 at 4:21 AM
    #38
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Haven't seen any thing in years with out them probably since they got rid of vent windows other wise the HVAC system would not work at all well or you would have to lower a window to get the air to move. Fairly
    unpleasant in the snow or rain.
