Truck Camping Photo Thread
Discussion in 'Outdoors' started by Maticuno, Jul 10, 2011.
  1. Mar 9, 2019 at 6:20 AM
    #6341
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    I agree man. Lots of glamping in here. But it is still camping. I been thinking about biulding me a big slide in camper still, but I am having trouble finding rv insulation and windows.
  2. Mar 11, 2019 at 2:41 PM
    #6342
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Ok.
    I’m planning on building a small DIY solar/roof top pressurized shower to mount on my shell rack for this year.
    Similar to this -
    https://www.rei.com/blog/camp/diy-car-top-solar-camp-shower
    Been doing my research and I have it all designed and planned out. Except for one thing...
    What to actually build it out of.. PVC or ABS. I like the idea of ABS since it’s already black and I wouldn’t have to paint it since I’m lazy. Plus I image an all black pipe would absorb more solar energy than a painted white one.
    But all the ABS I’ve been lookin at is DWV pipe so it has no pressure rating.
    I definitely wanna be able to pressurize it instead relying on gravity.
    I was also looking at the option of using a small electric pump to move the water out of the tank instead of air pressure.
    It’s hard I find accurate info on what kinda pressure ABS can actually handle.
    Who’s built one of these before and what did you end up using?
  3. Mar 11, 2019 at 5:57 PM
    #6343
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    I built one last year. Used it on top of my FWC last spring, summer, and fall. It worked ok and I'm happy I made it. Took some trial and error. Ended up buying more pieces and joining them together because on my first attempt I had to cut part of the pipe off and redo it. That REI video is actually pretty spot on for what you need to do. One addition could be a pressure relief valve. I put mine on the part which can be removed for filling the tube. Most of the sources I referenced for my build were done out of either black ABS or DWV pipe from what I recall. Without going to Lowes and checking I'm pretty sure that's what I used. I ended up painting my shower tube flat black to cover the lettering which is printed on the pipe.
    steveo27[QUOTED] likes this.
  4. Mar 11, 2019 at 7:17 PM
    #6344
    steveo27
    Pittsburgh
    I’ve been using a Coleman solar bag thingy and it gets warm enough to get a quick rinse in after a long day of fishing. I just hate having to set it up and take it down. Looking for a permanent solution to stay up on the shell and not break the bank.
    90% of the ones I’ve see seem to be made of DWV cellcore ABS
    Most of my inspiration and design come from this one
    https://m.youtube.com/watch?v=dG2HK9JsAjw
    Seems to be running 30psi with no issue.
    How much were you running in yours ?
    rebelchem and ETAV8R like this.
  5. Mar 12, 2019 at 12:23 PM
    #6345
    Chappy's_Strt_Tco
    Chappy's_Strt_Tco Member
    Chappy
    Tucson, AZ
    2013 Red 4-Door Taco
    Icon stage 4ish with RXT Leafs and secondary front shocks on Icon UCAs, 285/70/17's, DBZ Customs grille, Manual Trans, ARE Shell w/Prinsu Rack, Sliders
    In Ocotillo Wells a few weeks back. Had a blast!
  6. Mar 15, 2019 at 4:48 AM
    #6346
    Nomad_Pilot
    Clay
    Ft Collins
    ABS is UV stable, PVC pipe is not
  7. Mar 15, 2019 at 8:59 PM
    #6347
    steveo27
    Pittsburgh
    Right.
    Any thoughts about the pressure rating?
  8. Mar 17, 2019 at 8:47 AM
    #6348
    Nomad_Pilot
    Clay
    Ft Collins
    It depends on what type of ABS pipe it is. ABS 1208 is only rated for 15 psi, where as ABS 1316 is rated for almost 700 PSI !!!!
  9. Mar 17, 2019 at 1:27 PM
    #6349
    scaramouche
    scaramouche Well-Known Member
    This is maybe two years ago, Fort Churchill in NV
    Crom, Bryce, SIZZLE and 6 others like this.
  10. Mar 19, 2019 at 9:25 AM
    #6350
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Oh man, was this going to be fun. A trip like no other (so far). A trip with a twist. A trip that was actually two. Let me explain.
    For a while now, Anza Borrego Desert State Park in California has been on my list of places to explore. Like Death Valley - which we've visited quite a bit and recently hiked for three days - it's a great place to visit during the winter because temperatures in the summer can get rather unbearable - so much so that certain roads in the park are closed from mid-June to September. The problem is that the drive to-and-from Anza Borrego is a bit too long to make our normal 6-day jaunts worthwhile.
    So you can imagine my excitement when I realized that there was an opportunity to nearly double the length of the trip and cut the driving in half, all at the same time!
    To find out how, read the first chapter and see photos of my first experience in Anza-Borrego, check out:
    more photos and the full story:
    Double Fun @ Anza Borrego - March 2019 (Part 1)
  11. Mar 19, 2019 at 3:53 PM
    #6351
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Hahaha so true!
  12. Mar 19, 2019 at 3:55 PM
    #6352
    uploadadventure
    Dixon, Mo
    I want to know about that camper shell!
    Eazy.E likes this.
  13. Mar 20, 2019 at 8:11 AM
    #6353
    christyle
    christyle 107
    Chino Hills, CA
    2014 Raptor
    Guess i can post this here too from Anza Borrego last weekend
  14. Mar 20, 2019 at 8:21 AM
    #6354
    2Toyotas
    2Toyotas Well-Known Member
    Ken
    Western NC
    '13 Taco SR5 AC
    Toyota????? (Humor alert!!)
  15. Mar 20, 2019 at 1:40 PM
    #6355
    VMIgrad11
    VMIgrad11 Member
    2010 TRD Off Road 4x4
    Got to love those Expando Vans.
  16. Mar 20, 2019 at 5:08 PM
    #6356
    PinnaclePete
    PinnaclePete I am what I am
    Pete
    Central AR
    '14 Sport DCLB Pyrite, 2015 DCSB Barcelona Limited
    SwitchPros 9100, Flip Pac, Stealth 6 Bronze, Toyo 255/80/17, MTO Tailgate Skin, RCI read diff plate, StopTech slotted disc and pads, OME 885 w/ NitroChargers, OME HD LeafPacks, SOS Rear bumper with swingout, BAMF Bolt-on Sliders, Rear diff breather, OEM roof racks, ECG perforated grill, BAMF behind grill light bar bracket with PIAA 510 4" yellow spots, US OffRoad bumper, Engo 9k winch, WeatherTech window vents and floor mats, Wet Okle seat covers, RedLine hood struts, Anti Dark hood lights, Baja amber light pods, Lamin-X amber flood covers, amber FlyEyes, Jumpers amber LEDs, Salix glovebox and center console organizer, MagLite mounted, shop made bed mount tool boxes, LogRite bed mount bottle opener
    Posted this earlier in the Turd Gen Truck Camping Photo thread :crazy:
    Anyway, first shakedown overnighter in the Arkansas Ouachitas with my new-to-me Flip PAC. Quite the game changer from my Waypoint (ChandlerDoom) RTT.
    66B7DF04-78D0-43A9-AF58-F5D9D755C9CA.jpg 46D06B21-2516-41FB-A714-011B771A855A.jpg 54206D72-C2A1-4DC7-A71C-0838D6B63A48.jpg 2AE735D5-1BE4-43D1-AD11-F343CF485E25.jpg
  17. Mar 20, 2019 at 5:21 PM
    #6357
    ResearchMonkee
    ResearchMonkee Techn9cian
    Derrick
    KCMO
    2011 Barcelona Red DCSB Sport
    A love button.
  18. Mar 21, 2019 at 7:39 AM
    #6358
    turbodb
    Dan
    PNW
    AdventureTaco
    Saw that out there in Coyote Canyon as well last weekend. Pretty cool vehicle. Got a good laugh out of the "Expedition RV" stenciled on the side. :rofl:
    ...The sandy washes were fun to drive in and we made reasonably good time except for me stopping every couple minutes to take pictures. But really, how could anyone resist - the sun was out and the weather was a far cry better than the snow we'd left in Washington!
    catch up on the entire story here:
    scaramouche, Drainbung and bluezzy like this.
  19. Mar 21, 2019 at 1:29 PM
    #6359
    christyle
    christyle 107
    Chino Hills, CA
    2014 Raptor
    You mean to tell me we were out there at the same time?!
  20. Mar 21, 2019 at 1:52 PM
    #6360
    turbodb
    Dan
    PNW
    AdventureTaco
    Apparently you, me, and A LOT of other people. Man, Coyote Canyon and Sheep Canyon were busy, weren't they?!? We much preferred more remote parts of the park, though the flowers in Coyote Canyon were spectacular.
    Drainbung likes this.
