Truck can't get aligned, pulls right
Discussion in '1st Gen. Tacomas (1995-2004)' started by eon_blue, Apr 28, 2020.
  1. Apr 28, 2020 at 12:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @eon_blue
    Way too much to read so not sure this was asked; you're using shims you said?
    What if one shim is installed backwards?
  2. Apr 28, 2020 at 12:42 PM
    eon_blue
    eon_blue [OP] If I would, could you
    Azusa, CA
    yep got the shims on there, both are on correct (pointed ends facing toward cab). I did just go out and double check though lol.
    This was also going on with the Expos before the Alcans, initially thought maybe the Expos had a bent pin or spring but it's either the housing or the axle shaft, probably the housing.
    If the housing is the case then all I can think of is that I need to re-install the leaf springs and pay more mind to the placement of the rear axle on both sides before I torque everything down. Short of the frame being tweaked, I can't see why else the housing would be askew. Unless the leaf springs themselves were different lengths but they're the same (measured).
    Kwikvette[QUOTED] likes this.
  3. Apr 28, 2020 at 12:45 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Could the bed be on crooked and the vibration be a separate issue?
  4. Apr 28, 2020 at 12:50 PM
    P.Blackley
    P.Blackley Well-Known Member
    Patrick
    Layton, UT
    99 Tacoma 4WD SR5
    Fox extended coilovers, LR UCA's, Deaver J59's W/ 12" Fox triple bypass shocks
    If you had a bent axle shaft it would kill the seal off pretty quickly, as that's what happened to mine.
  5. Apr 28, 2020 at 12:59 PM
    eon_blue
    Azusa, CA
    I thought of that but the bed gap between the cab and the bed is the same on both sides
    good to know, thanks. No sign of any gear oil on the wheels or drums so I think the seal is good, points more toward the housing than the axle shaft.
  6. Apr 30, 2020 at 6:13 PM
    eon_blue
    Azusa, CA
    Update: got new U-bolts today, when I put those on I'm going to drop the axle a bit and see if I can't figure out what the issue is. Hopefully when I line it up and torque it down again with the new u-bolts it'll be good.
    If not, I'm going to have my local 4x4 shop look at it and see if they can determine the problem.
    Just gotta wait for a day that isn't so freaking hot, we got hit with a heat wave. Good ol socal
  7. Apr 30, 2020 at 6:22 PM
    svdude
    svdude Well-Known Member
    jonathan
    Maybe measure from the center of the diff housing to the end of each axle tube, use a straight edge or something that is known to be straight. If the numbers don’t match then your housing is bent.
    eon_blue[OP] likes this.
  8. Apr 30, 2020 at 7:50 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    The most accurate way to check the axle tube may be to use an alignment bar. You'll have to remove the center diff and the axles and use the alignment bar through the whole housing. Measuring will get you close but if you still can't tell. That's the best method. Heres a quick link for one. You'll have to find a shop that has one for Toyotas. Other than that I'm not sure which methods will get you the most accurate measurements...
    https://www.summitracing.com/parts/...czh4pbwvqa-BFR4NQuR7o6KZ4NlrA9yAaAjnUEALw_wcB
  9. Apr 30, 2020 at 7:59 PM
    eon_blue
    Azusa, CA
    Thanks for the idea, I hadn't thought to measure it that way. I just went out and did it. Driver side front hub to rear hub is 122 inches and passenger side front hub to rear hub is 124 inches. This confirms the rear axle housing is the issue in my mind, also explains the strong pull to the passenger side.
    So basically I need to see if I can resituate my rear axle to be an inch further up on the driver side, which would push it back an inch on the passenger side and theoretically be straight. Hopefully I can achieve this when I loosen it from the leaf springs to put in my new u-bolts. I'm skeptical though because I really don't know if there's any adjustment to be made like that, the springs sit on the axle where they sit. Not like there's room for movement there
    High Noon likes this.
  10. May 1, 2020 at 6:32 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    This is one of those things at least one other person to help two would be better .
    Dumb question mismatched springs I can`t recall if you checked that already .
    Both shackles in the some position not one pushed back and one pulled front?
    Just some ideas !
  11. May 1, 2020 at 8:49 AM
    Wulf
    Wulf no brain just damage
    rock raisin
  12. May 1, 2020 at 8:57 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    When I bent an axle shaft you could see the tire wobbling in the mirror. If the whole thing is crooked, it wouldn't be an axle shaft.
    There's two holes in the perches from the factory, although one's smaller, wonder if you have one centering pin in the wrong hole OP. (how many jokes can be made on that sentence? don't know how else to phrase it ):rofl:
    jubei, SR-71A and Wulf[QUOTED] like this.
  13. May 1, 2020 at 9:01 AM
    Wulf
    rock raisin
    Hope he lubed it up a little bit instead of just jamming it in there dry
    SR-71A likes this.
  14. May 1, 2020 at 9:15 AM
    eon_blue
    Azusa, CA
    Yea I noticed the smaller hole behind the mounting hole, but it's way too small for the center pin to fit. Both pins are centered in the right spot
    I don't think it's the axle shaft anymore either based on what you said and others talking about how it vibrates, kills the axle seal, etc. I don't have those symptoms. My rear axle housing is misaligned somehow though and I gotta figure out why.
    Front to rear hub driver side - 122in
    Front to rear hub passenger side - 124in
  15. May 1, 2020 at 9:25 AM
    #35
    Squeaky Penguin
    Brett
    That seems really odd. Measurement from the front leaf hanger bolt to centering pin same side to side? Lift height about the same/shackles at the same angle? Doesn't sound like leaf problem.
  16. May 1, 2020 at 10:12 AM
    #36
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Wow, 2" difference is huge.
    This was hard to get my head around so I had to go measure mine to see. FWIW, mine is 123.5" +or- .125" on both sides. I found it challenging to be more accurate than that using a tape measure and the 'center of the hubs'.
    Ryan, if my numbers are consistent and normal, the side of your truck that is 122" is the problem side IMO. Your 124" measurement is pretty close to norm I think.
    Just going to throw this out there because I don't think its been mentioned and for that matter, how it would even be possible, but is the leaf pack oriented correctly front to back? I forget the length difference between the center pin and the front mount and the center pin and the shackle end.
    Were those leaf packs disassembled and reassembled?
    eon_blue[OP], EatSleepTacos and Wulf like this.
  17. May 1, 2020 at 10:33 AM
    #37
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    After the first few posts I was thinking possibly the axle hub flange was to blame, but after reading through the posts doesn't seem like the case.
    I didn't read everything very carefully, but what I would do is drop the axle, take measurements of The springs, hangers etc, verify that all is square/plum. If that's all good find, put the axle on jack stands and level it out, get something that is straight and clamp it to the rims, parallel to the axle, take measurements to verify everything is square and parallel to the axle, hubs, leaf mounts.
    2in off is a lot, but just a small amount on one side will compound itself over the length of the axle. 1/32 can turn into 2in fast.
    Wyoming09 and eon_blue[OP] like this.
  18. May 1, 2020 at 10:40 AM
    #38
    eon_blue
    Azusa, CA
    Yea I don't think it's the Alcans either, I measured both before install and they're equal.
    They're brand new Alcans, and I had a bad pull with my Expos previously too. I had hoped when I installed the Alcans that the issue was with the Expos but when the pull persisted I knew I had to consider the axle housing or something else (frame, maybe? But the cab-bed gap is equal on both sides and I have no other signs of a tweaked frame).
    Yea 2" seemed pretty severe to me at first but then I figured its really more an issue of one inch, right? Because if I am able to correct the axle 1" one way it'll move one inch the other way and be even. If I'm thinking about it correctly, at this point I'm planning on dropping the axle on Sunday to put on the new u-bolts and hoping I'll have a better look at it then
  19. May 1, 2020 at 10:44 AM
    #39
    eon_blue
    Azusa, CA
    Sorry for the typos, I get carried away with the damn swipe text feature on my phone lol
  20. May 1, 2020 at 11:08 AM
    #40
    nagorb
    Alabama
    2001 dbl cab 4x4
    Could be, but could also be all on one side. I'd say most anything right now is speculation until you pull the axle. Any measurements now could be skewed.
    eon_blue[QUOTED][OP] likes this.
