Truck cap seal
Discussion in 'Tonneau Covers, Caps and Shells' started by Sean4X4, Dec 27, 2018.
  1. Dec 27, 2018 at 1:28 PM
    Sean4X4
    Sean4X4 [OP] Member
    Sean
    2014 Silver Tacoma LTD Double Cab Long Bed
    Hi, I have a Tacoma (2014 LTD with double cab & long bed), there is a gap between the rear window & the truck bed cap, anyone know an elegant way to seal it ?
    I need to seal it from the top to keep the rear view clear from rain, snow, etc but has to be a good looking solution please & thanks.
    MJ-12 and irayfz6 like this.
  2. Dec 27, 2018 at 1:37 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've been driving trucks with caps for 40 years. Never had a problem with that. That is why they have mirrors on the sides. About once a year I loosen the clamps and slide the cap back about 6" to clean the glass on the back window of the truck and front of the cap. Some newer caps will allow the front window on the cap to easily come out making it a lot easier to clean. The one on my F150 does that.
    MJ-12, Sig45 and irayfz6 like this.
  3. Dec 27, 2018 at 1:44 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome to TacomaWorld!
    MJ-12 likes this.
  4. Dec 27, 2018 at 1:57 PM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    home depot or lowes has a few different types of weather strips that will probably work
    MJ-12 likes this.
  5. Dec 27, 2018 at 2:08 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Also had trucks with caps since 1999 and never had an issue with rain, snow and/or ice affecting visibility in that area. The heat from the truck melts any snow/ice that does manage to get back there (which isn't a lot).
    I've never seen a truck with a cap with that top space/gap sealed.
    The rear cap/door window is the problem as it's non heated space. That has to be brushed/scraped clean for proper visibility.
    I've always had either a sliding or removable cap window to allow for occasional washing of the rear truck window.
    MJ-12 likes this.
  6. Dec 27, 2018 at 2:20 PM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    There are inflatable boots to seal between the cab and cap but some people report that they rub the paint off. I have not had a problem with rain, snow or ice in that area having caps for 25 years.
    MJ-12 likes this.
  7. Dec 27, 2018 at 4:35 PM
    MJ-12
    MJ-12 Well-Known Member
    Tee
    Houston, Texas
    2018 Limited 4x4 Mag Grey
    Stock
    Welcome!
  8. Dec 28, 2018 at 3:55 PM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    I've never had a problem with snow or ice building up in that area. But there are other reasons to seal the gap. Unfortunately there's probably not an elegant way to seal it. Any sort of boot is bound to causing scratching. I've tried inflatable boots and weather stripping. They work but aren't perfect.
  9. Dec 29, 2018 at 4:32 PM
    Go Fish
    Go Fish Well-Known Member
    2022 SR5 4x4 DCLB
    On a previous truck I had a canopy with a factory boot instead of a front window. It made a very nice pass-thru between the sliding rear window and the canopy. I don't know if it scratched the truck because I left the canopy on. It did eventually develop a leak in one corner. You might ask a canopy installer if it is possible to remove the front window and install a boot.
  10. Jan 15, 2019 at 6:24 PM
    Sean4X4
    Sean4X4 [OP] Member
    Sean
    Thanks to all of you guys, definitely great opinions & options for me to consider.
