truck chatters when i hit the brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Grind'emTillYouFind'em, Nov 6, 2016.
  1. Nov 6, 2016 at 11:04 AM
    Grind'emTillYouFind'em [OP] Active Member
    Jonah Alt
    2002 white and black tacoma sr5
    leveling kit, black rims, grill guard, light bar, taillights
    I recently changed the drums on 2002 Tacoma and once I did, the truck started jumping around when I hit the brakes. It gets a lot worse when I try and downshift. To me it sounds like its not going all the way out of gear or something but I can hear a metallic racking sound when I push the clutch in. sorry if I don't have a better description than that its kind of hard to describe.
  2. Nov 7, 2016 at 1:48 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Hard to say but surly it has to do with the new drums...are they cheapish chinese drums? They could be worse than whatever you had on there to begin with. Its not too uncommon to get new cheap drums that are out of round.
  3. Nov 7, 2016 at 3:57 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    I would also think it was caused by the new drums. You could take them back off and have them turned if you have not already done that.
  4. Nov 7, 2016 at 6:25 PM
    TacomaNeophyte
    TacomaNeophyte Member
    2003 Tacoma 4x4 2.7L
    I had issues with the dealership that sold my truck only replacing the drums and rotors but not the pads and shoes. The truck would shake quite aggressively when braking. The apparent cause was the drum cylinders leaking causing the shoes to grab inconsistently. I ended up replacing the calipers, pads, shoes, and drum cylinders and all is well now.
  5. Nov 8, 2016 at 1:34 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Did you get grease on the shoes and forget to clean.
    Some drums may very well come with oil/ rust preventive on to prevent rust on the long boat ride
    anything like that on shoes or drums will cause that issue
