truck cut off while mudding?
Discussion in '1st Gen. Tacomas (1995-2004)' started by fireturk41, Mar 17, 2010.
  1. Mar 17, 2010 at 6:50 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    hey yall i was mudding with the chicka today, i got hung up on my rear pumpkin and got stuck for a few minutes. while i was trying to get out my engine cut off, i cranked it, when i let of the accelerator, it cut off, repeat 2 times, by the time i finishe the trail the problem quit, my hood wasnt wet my airfilters dry and my exhaust wasnt under water when i got hung up. ive drivin it aprox 50 miles since
    any suggestions as to what it was?
    btw it was awesome, i wish i took pics
  2. Mar 17, 2010 at 6:59 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    :notsure: I would just check and make sure everything is connected underneith. The only time I have ever stalled out like that I had a wire that fell onto my manifold and shorted out my fuel pump.
  3. Mar 18, 2010 at 11:01 AM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    idk it was weird, it was like when my idol air control died except it fixed itself. i havent had any problems since so im not worried bout it. it was just weird, i gotta go back today because i forgot my fishing pole, ill just hit the skinny pedal a lil harder going through
  4. Mar 18, 2010 at 11:07 AM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    You got water/mud up in an elect connection and it cut out/ shorted out your spark/ignition/computer. It dried out with engine heat. Using skinny pedal with great enthusiasum will only cause this to be worse
  5. Mar 18, 2010 at 11:21 AM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    :popcorn:
  6. Mar 18, 2010 at 2:40 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    went back today did just fine and no cutting off :D thats the last time i try to show off in 2wd :D
