Truck dead!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smcgill, Nov 10, 2009.
  1. Nov 10, 2009 at 4:43 PM
    smcgill
    smcgill [OP] Well-Known Member
    Sean
    South Easton Mass. not enough time in Cocagne NB
    Camry and Ram 1500 with a "HEMI "
    Has anyone gotten in there truck and nothing happened.:confused:
    No lights :confused:
    No start :confused:
    No alarm :confused:
    No door locks :confused:
    etc.
    Looked under hood and did that look @ thing and wiggled the batt. cables .
    Then every thing worked ?:confused:
    So now I have to redo the seat belt chime do hicky again.:mad:
  2. Nov 10, 2009 at 4:49 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    well maybe the battery cables were loose
  3. Nov 10, 2009 at 4:51 PM
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
    For starters tighten down your battery cables and your grounds.
  4. Nov 10, 2009 at 4:53 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Maybe :confused: it was a bad :mad: ground :tumbleweed: :confused:
    Take it :turtleride: to the garage :notsure: and see :eek: if the can find :poking: the bad ground :tumbleweed: and fix it :goingcrazy:.
    Cheers :cheers:
  5. Nov 10, 2009 at 4:58 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    that happened to me it was the battery.
  6. Nov 10, 2009 at 5:02 PM
    smcgill
    Sean
    That was a test.
    Of course I should fix that.
    But NOTHING worked NOTHING .
    I couldn't lock it.
    I know use the key , but you forget you can.
    Also I couldn't shift the truck .
    So what if you broke you Batt. / cable how do you tow it?
  7. Nov 10, 2009 at 5:07 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    an auto? turn the key, press the brake and shift into N ??? you shouldnt need a battery to do that:boom:
  8. Nov 10, 2009 at 5:21 PM
    ROCKSLINGER
    ROCKSLINGER Zombie Response Team
    Robert
    Reno Nv
    14 MGM DBL CAB 6 SPEED
    Fox Coilover with reservoir, Fox Remote Rear reservoir, Wheeler's 3 pack AAL, Grillcraft Grille color matched, Rampage 50" LED Light Bar, Relentless 1/4" IFS-Mid and Transfer case Skids, Relentless High Clearance Rear Bumper, Kenwood 1800 watt Amp, 12" Rockford Fosgate P3 Shallow Sub, 1 Farad Capacitor, Redline Hood Struts, Weathertech Floor Mats, Doug Thorley Long Tube Headers, Flowmaster Delta 40, URD MAF Calibrator, URD Short Shifter, CST Black Leather W/Red Stich, On Board Air, Train Horns,
    I would recommend take off and clean your battery post and terminals even if they dont look corroded. If you dont have a cleaner its only a few dollars at your local parts store. And tighten down your terminals good and tight. This could help your problem. You might even service your battery and pop the tops off and fill with water.
  9. Nov 10, 2009 at 5:44 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    see if the lil green l.e.d. on the battery has any glow, or worse if its yellow.
    and of course , jump start it.
  10. Nov 10, 2009 at 6:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    THe Parking lock is released via an electronic solinoid. If no power...it no worky
  11. Nov 10, 2009 at 6:43 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    SHITTY!!!:crapstorm: :rant:
  12. Nov 10, 2009 at 6:51 PM
    Tacoyota
    08 4wd
    Bah! I missed the part "....and then it worked" , the beer made it ok though, so no worries here.:drunk:
    Yer bat'ry is commoded man. Git'cher self a metric crescent wench and fix yer stuff man. ...And don't lick the terminal to see if thar is some voltage!:D
  13. Nov 10, 2009 at 6:53 PM
    98tacoma27
    Ben
    Not Beech Creek
    Is there a manual bypass? I think some vehicles have a button or spot where you use the key to override it.
  14. Nov 10, 2009 at 6:55 PM
    militaco
    militaco Well-Known Member
    Hawaii
    2009 Double Cab, '99 Regular Cab
    I've had that on my corolla......if nothing lights up....it could be the alternator went bad.
