truck died, im lost.......
Discussion in '1st Gen. Tacomas (1995-2004)' started by beefcake, Sep 9, 2010.
  1. Sep 9, 2010 at 1:18 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    so yesterday i was coming off the freeway doing about 60, i pushed the clutch in and pulled the truck out of gear and just coasted to the light. before i got to the light i noticed all dash lights were on (as if i had just turned to accesory) then i look at my rpms and they were at 0. i did just chang my alternator about a week ago or so, the truck hasnt done it again...anyone have an idea as to why it did that?
  2. Sep 9, 2010 at 1:29 PM
    aaronatl
    aaronatl ©1975
    Aaron Nrsa
    In A Big Country
    it hauls tostitos
  3. Sep 9, 2010 at 1:31 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Doubt the alternator install had anything to do with it, you'd have known any issues right away I'd think. When I had manual shifts in the past once in awhile coming off the freeway I'd do the same thing (put it in neutral & coast) & it would die, I think it may have something to do with traveling at speed for awhile (like on a freeway) & abruptly dropping to idle speed, your truck had a bit of a hiccup , & stalled. Did it start back up easily ? & hasn't happened since ? I'd say not to read to much into it, maybe change fuel filter or remembering when the last tune up was, I dunno, until it starts happening frequently would't stress too much.....:cool:
  4. Sep 9, 2010 at 1:36 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    yeah it started right back up just fine, ive only had the truck for just over a year and both plugs, wires and fuel filter have been changed in that time period
  5. Sep 9, 2010 at 1:51 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Like I said if its only done it once, wouldn't really give another thought until it starts to be a pattern....:D
  6. Sep 9, 2010 at 1:54 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    ok man thanks for the advice hope it was just a hiccup :)
  7. Sep 9, 2010 at 2:06 PM
    beefcake
    beefcake [OP] J-rob
    J-Rob
    Central California
    98 4WD V6
    alright well i'll keep you guys updated if anything else goes wrong, other than that truck is runnin 180k strong :)
  8. Sep 9, 2010 at 3:16 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Don't forget to keep intake butterfly clean.
  9. Sep 9, 2010 at 8:55 PM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    Is this as easy as removing the screw clamp, setting the hose aside and cleaning the blade?
  10. Sep 9, 2010 at 9:31 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :laugh: Ah, what fond memories. Life was so simple...
  11. Sep 9, 2010 at 10:50 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yep, its all gone the way of the Ballast Resistor & the old GM Distributor with the little window you could set the point gap & dwell on the fly....;)
  12. Sep 10, 2010 at 8:08 AM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    essentially, yes...realistically, no. The intake tube can be a MF to get out of the way to really clean.
