Truck Died On Freeway
Discussion in 'Technical Chat' started by dmigod, Jun 21, 2010.
  1. Jun 21, 2010 at 1:02 PM
    dmigod
    dmigod [OP] Member
    Paul
    Stockton CA
    2007 TRD 4X4 Extra Cab Tacoma
    My 2007 Tacoma 4X4 died this morning while driving 70 MPH in the fast lane on my way to work. All lights came on the dash and the engine just died. Coasted to the side with the truck still in D. Checked under the hood, battery cables etc looked in place. Tried to start truck and it turned the engine over but would not catch. Towed it to my Mechanic. Anyone else had this issue? I searched first but could not find an answer. Thanks in advance. I have loved my truck until today. 41K miles. Alll service up to date. Last 40K service done by Lodi Toyota in CA.:confused:
  2. Jun 21, 2010 at 1:04 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    shitty keep us updated.
  3. Jun 21, 2010 at 1:04 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
  4. Jun 21, 2010 at 1:04 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    dam, that sucks, do you know anyone with a scangauge? check all the fuses too, and make sure your ECU is intact with no wires hanging off
  5. Jun 21, 2010 at 1:05 PM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    Damn. 1st welcome to tw. Second, did you hear any noises or see any smoke? If all lights came on and truck turned but still didn't catch its probably your fuel pump. There are three components to ignition air, fuel, and a spark. Sound like you have air and spark but no fuel.
  6. Jun 21, 2010 at 1:06 PM
    EEtaco
    EEtaco Well-Known Member
    North Carolina
    09 V6 Prerunner
    Since it just died when you were on the road I'd look at the fuel system. Something may have made its way in there and clogged the lines or filter. Did the truck throw any codes when you tried to start it?
  7. Jun 21, 2010 at 1:12 PM
    dmigod
    dmigod [OP] Member
    Paul
    Stockton CA
    The truck showed nothing when I tried to restart except for the red battery light stayed lit. I had it towed to my frieds shop and I will post up what he says this afternoon. Thanks for the welcome and for the assistance. :)
  8. Jun 21, 2010 at 1:16 PM
    OCTaco
    OC
    '16 TRD Sport DCSB
    Im thinking it's your battery then.
  9. Jun 21, 2010 at 1:18 PM
    just_hurri
    just_hurri Member
    Justin
    Texas
    99 PreRunner TRD
    I had similar case when timing belt tensioner bearing let go.. I had over 100k on her though. Hopefully your problem is not so drastic as mine was.
    Post up when you find out!
  10. Jun 21, 2010 at 1:18 PM
    Dilsky
    Dilsky There go my nipples again!
    Shawn
    Edmonton AB
    07 TRD Sport
    2.5" Fox Extendable Coilovers, LR UCAs, Agri-Cover Larado soft top, Pop'n Lock, 48" Hi-Lift Jack, 20" Incubus Offroad rims
    If it turns over, the battery is still good.
  11. Jun 21, 2010 at 1:19 PM
    EEtaco
    North Carolina
    09 V6 Prerunner
    A bad battery wouldn't cause the truck to fail going down the road would it?
  12. Jun 21, 2010 at 1:25 PM
    Manwithoutaplan
    ID
    maybe a bad alternator :tumbleweed:
  13. Jun 21, 2010 at 1:29 PM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2006 Infiniti M35x
    Sounds very much like a bad alternator to me. Technically, your battery isn't really in use when the car is running, your alternator is. It turns over because you have battery power. Just my guess.
  14. Jun 21, 2010 at 1:31 PM
    Chad
    Chad Well-Known Member
    Chad
    Raleigh, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- BHLM -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- 09+ Access Cab Rear Headrest Removal
    x2. My father had to have his alternator and radiator changed on his 00. Truck would turn over but would not fully start.
  15. Jun 21, 2010 at 1:34 PM
    dogbite
    dogbite Well-Known Member
    Utah
    '10 double cab TRD OR
    OME lift, Leer shell, Beefed sliders, Extra 12V outlets for rear bench
    It'll run on the just battery with a blown alternator, at least for a little while 'til you drain the battery.
    With the modern computers though an aging dying battery can strand you like that. It's still got power, but the voltage isn't enough to run the computer so it never starts. At least I've seen that in some other vehicles, mostly Dodge minivans.
  16. Jun 21, 2010 at 1:36 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Wow, this sounds really weird. Subbed to hear what it turns out to be. :popcorn:
  17. Jun 21, 2010 at 1:40 PM
    Manwithoutaplan
    ID
    I killed my Alternator Off-roading in Very grain mud water... OH joy!!! 700 bucks later.
  18. Jun 21, 2010 at 1:41 PM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Pro grille, remote start, tailgate inserts, nifty key fob
    If the engine slowly sputtered and then died, it is probably fuel related.
    If it quit instantly, it is most likely something in the electrical system.
  19. Jun 21, 2010 at 1:49 PM
    PB65stang
    Patrick
    Kansas City
    2006 Infiniti M35x
    Yup. Which is precisely why I think it's an alternator.
  20. Jun 21, 2010 at 4:47 PM
    dmigod
    dmigod [OP] Member
    Paul
    Stockton CA
    My guy is too busy today. Hopefully he can look at it tomorrow morning:(
