Truck dies after a few seconds
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Slick rick, May 17, 2021.
  1. May 17, 2021 at 11:30 AM
    Slick rick
    Slick rick [OP] Member
    Rick
    2005 black toyota tacoma trd
    None
    Hi I am slick Rick in park city ut. Have 2005 toyota tacoma TRD black 198000 miles. I had it since new and it's been an awesome truck.
    I changed oil and filter, plugs, air filter washed dirt off. Now starts runs 2 or 3 seconds then dies. I changed cor, maf, cam positioning sensor and still same thing. Fuel pump runs when you first turn key then stops even while still cranking.
  2. May 17, 2021 at 11:33 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Besides loading and firing the parts cannon. What have you done for diagnostics or to isolate the problem?
    12TRDTacoma and tcBob like this.
  3. May 17, 2021 at 11:42 AM
    Slick rick
    Rick
    None
    Checked all elect. Connections under hood ran fuel hose from under hood into bucket got fuel pressure when you first turn key then nothing. Waiting for parts for fuel pressure gage
  4. May 17, 2021 at 11:45 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    CEL on? Are the anti-theft indicators normal? Assuming they are, FP reg is the first thing that comes to mind, but really a full system scan is what is needed.
    12TRDTacoma likes this.
  5. May 17, 2021 at 12:06 PM
    Slick rick
    Rick
    None
    How can I check anti theft to see if it is working properly?
  6. May 17, 2021 at 12:13 PM
    tirediron
    Look at the light(s) is the behaviour correct (as shown in your manual), or is it flashing in a way that may indicate a fault? Your best bet is to head a major auto-parts store; most will have a scanner which you can use free of charge and will give you all the codes in your system.
  7. May 17, 2021 at 12:14 PM
    HoosierBuddy
    HoosierBuddy Well-Known Member
    Phil
    2012 Base Regular Cab 4WD Manual
    2" Lift
    I'm going to take "clogged fuel filter" for $10.
    Phil
    Torspd, Lawfarin, barf and 2 others like this.
  8. May 17, 2021 at 12:17 PM
    Slick rick
    Rick
    None
    I need check lights to see thank you I'll be back.
  9. May 17, 2021 at 2:14 PM
    Knute
    Simple. Lock it up. Try to break in and hot wire it.
    airmax233 and barf like this.
  10. May 17, 2021 at 6:23 PM
    tirediron
    Good point - how does it die? Sputters and slowly dies, or stops immediately?
  11. May 17, 2021 at 6:34 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Toyota's are weird, I think the fuel pump kicks on and primes/pressurizes the system and then shuts off until you actually crank the engine over. Is there a separate fuel pump relay for the pump once you actually crank the engine over? Is there another relay with the same specs in the fuse/relay box you could swap in and see if there is any difference?
  12. May 17, 2021 at 6:35 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    These truck use a fuel pump resistor.
    The pump operates on High at start up, and changes over quickly to the low speed (through the resistor) once started.
    Maybe jump the resistor and see if it stays running.
    Torspd, Marc70 and 12TRDTacoma like this.
  13. May 17, 2021 at 7:36 PM
    Markjchang
    Markjchang New Member
    Mark
    2013 Tacoma TRD OR
    I'm having the same kind of problem. I checked the relay by bypassing it and jumping wires together. There truck would stay on. Tested the resistance on the resister. It read on the multimeter. It read .7 then .8 which is close to what it's supposed to be. I put the resister back in, same problem. Any ideas? Thank you.
  14. May 17, 2021 at 7:41 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Not a thing on these gen trucks.
    The fuel pump energizes and runs full speed at key on engine cranking, not key on engine off like GM does.
    This right here. I would try this OP.
    And for god sakes quit blowing all of your money on unnecessary parts trying to shotgun fix it man. That's a horrible way to fix a vehicle and will often make it more unreliable then before you started after the fact due to the interior quality of parts you just installed.
  15. May 17, 2021 at 7:43 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Since nobody stated if they are a 2TR or 1GR Here are the circuits to both as they are very different: I assume a 1GR as you said Fuel Pump Relay which the 2TR doesn't have.
    How did you bypass the fuel pump relay and what did you jumper? Use the prints below to describe.
    2TR-FE Fuel Pump Circuit:
    The COPN Relay is what actually turns on the fuel pump.
    1GR-FE Fuel Pump Circuit:
    The Fuel Pump Relay only shifts between the high and low speeds as commanded by the ECU.
    The COPN Relay is actually what turns on the fuel pump.
    TnShooter likes this.
  16. May 17, 2021 at 7:49 PM
    BringbackSnacks
    BringbackSnacks Mr Steal Your Habibti
    Pasadena,CA
    2017 TRD PRO
    You should talk to the 200k no problem guy. @bigoldbeef
  17. May 17, 2021 at 8:30 PM
    TnShooter
    Deogee
    STOCK
    FWIW, I assumed it was the 4.0 since his profile said TRD.
    Unless they made a 2.7 TRD?
    Thanks @Jimmyh
    Jimmyh likes this.
  18. May 17, 2021 at 8:40 PM
    TnShooter
    Deogee
    STOCK
    I don’t follow exactly what you are saying?
    Are you saying that you jumped the relay AND the resistor?
    Or did you try them independently?
    Jimmyh likes this.
  19. May 18, 2021 at 6:05 AM
    HoosierBuddy
    Phil
    2" Lift
    Isn't there a fuel filter in the tank in front of the fuel pump as part of the fuel pump assembly?
    Filter is clogged and/or pump is weak. When pump has full voltage it barely pumps enough fuel to bring the engine to idle. ECU sees idle. Drops voltage. Now pump slows and can't keep up. Engine dies.
    Phil
  20. May 18, 2021 at 6:20 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    What is the fuel pressure? First things first.
