Truck dies immediately after starting?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OneFastXR, Jan 7, 2018.
  1. Jan 7, 2018 at 12:45 PM
    OneFastXR
    OneFastXR [OP] Member
    Jon
    2008 Toyota Tacoma XRunner
    Short shifter, led tail lights
    So I hade this same issue 2 months ago and after 2weeks a check engine light finally came on. Scanned the truck and found out that the MAF sensor was bad, replaced with new one, cleared the codes and truck ran again.
    I recently have replaced spark plugs, new fuel pump, brand new lowered suspension.
    Currently I went back to store and bought a new MAF sensor and still having same problem. I have no check engine light on now.
    Any suggestions?
  2. Jan 7, 2018 at 12:54 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    What spark plugs did you use and were they gaped properly?
  3. Jan 7, 2018 at 1:08 PM
    OneFastXR
    Jon
    Bosch plugs and yes
  4. Jan 7, 2018 at 5:46 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Chipped key? Try your spare.
    koditten likes this.
  5. Jan 8, 2018 at 9:03 AM
    OneFastXR
    Jon
    No chipped key. There is an aftermarket alarm from last owner
  6. Jan 8, 2018 at 10:23 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    :bananadead:
  7. Jan 12, 2018 at 12:37 PM
    OneFastXR
    Jon
    It does run on starting fluid. When I MAF plugged in it starts and dies immediately. I unplug it and it’s able to stay running
  8. Jan 12, 2018 at 4:51 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Tell-tale signs of a bad MAF. Did you buy a Denso MAF - OEM - or one of the cheaper after-market MAFs. But...it could be a wiring issue as well. Go back and look up all of the things that can cause the code you pulled. Go thru each one meticulously.
    OneFastXR[QUOTED][OP] likes this.
  9. Jan 14, 2018 at 1:01 PM
    OneFastXR
    Jon
    I bought the OEM Denso MAF sensor
