Truck dies when started on incline.
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpeedoJosh, Jan 27, 2014.
  1. Jan 27, 2014 at 1:14 PM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    So I (as well as many others) have a hard start issue with the 4cyl when the engine is warm. Can't figure out the issue. It always starts, just takes more turns then I would like, and when it does start, it's a weak start, and stumbles for a second or two. After it's running, it seems fine though.
    Yesterday, I parked on an incline. Came back 10 minutes later. Had the usual hard start, but this time it died immediately after starting. Tried again, same thing. Went for a third time, and immediately gave it some gas and it stayed running. :confused:
    Truck had 1/2 a tank, so had plenty of available fuel. Initially the hard start issue was said to be too much fuel going to the engine, and it being "flooded". The fact that the truck wouldn't stay running without giving it gas suggest otherwise (in my non-mechanic head).
    Any insight? I also have a P0171 code (Lean bank 1) that popped up about 5 months after the hard start issue began.
  2. Jan 27, 2014 at 1:22 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Maybe you have some fuel vaporizing in the line and your fuel pump has to move more fuel to get it to your injectors?
    Or, you have a small leak in your fuel line and it allows the fuel to travel back towards your tank? (fuel pump still needs to move it farther than normal to get it to your engine)
    Or, your fuel pump is going bad?
  3. Jan 28, 2014 at 7:35 PM
    SpeedoJosh
    Florida
    I thought fuel pump, but the fact that it starts fine in the morning when cold kind of confused me. It also runs fine, (except for about 5 mins after I clear the P0171 code it runs like crap). I just did about 12 hours of straight driving on the interstate without issue.
  4. Jan 30, 2014 at 5:29 AM
    chozomo
    chozomo Active Member
    Adam
    Vermillion, Alberta
    10 DC TRD White, 92 SR5 pickup
    Extra fuel tank, fire ext, light force driving lights , TRD exhaust, ARB and Warn winch, Bushwhacker, toytec ultimate lift, dakar leaf springs, 18' ATX thugs
    Maybe your fuel filter or a dirty fuel tank. On the 2005 and newer models that code brings up an air fuel ratio sensor could be that to.
  5. Feb 2, 2014 at 11:46 AM
    SpeedoJosh
    Florida
    Yea, the fuel filter was a thought of mine. It's a process on these 2.7s. Probably going to tackle it next weekend.
    Nice truck btw.
  6. Feb 2, 2014 at 12:49 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    The FSM shows the following possible culprits for a P0171:
    - Air Intake hose loose
    - fuel line pressure (bad regulator?)
    - blocked injector
    - bad o2 sensor (pre-cat)
    - MAF
    - coolant temp sensor
    - gas leakage on exhaust system
    That last item doesn't make any sense to me.
    Check all the hoses and electrical connections for the above systems. Check resistance for sensors and injectors.
