Truck dies when warm starting
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dogs, Oct 3, 2017.
  1. Oct 3, 2017 at 8:29 PM
    Dogs
    Dogs [OP] Well-Known Member
    Nick
    Missouri
    02 tacoma TRD SR5
    My truck does this weird thing where it dies the second time I start it. I'll explain better with a scenario. So I leave my house to go and get gas. Truck gets warm and does fine to get there and the cold start is fine. Then, after I finish getting gas and go to start the truck, it'll idle super low. Like 200rpm low. Then if I don't give it a hard rev in park it'll die. Sometimes it'll even die after I rev it up a bit. I have no idea what it could be and it has been happening for a while. And it only does this while its warm. Does anyone have an idea on what could be causing it?
  2. Oct 4, 2017 at 2:08 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Only after you fill up with gas?
  3. Oct 4, 2017 at 2:21 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I had a similar issue ended up being a bad injector on cyl6 it progressively got worse until it would cause misfires when started warm.
  4. Oct 4, 2017 at 5:46 AM
    tacoma665
    tacoma665 Well-Known Member
    Wisconsin
    2001 DCSB SR5 4x4 Lunar Mist 2009 DCSB SR5 4x4 Black
    I had a similar problem with mine. I cleaned up the IAC (idle air control valve) and it's been fine ever since.
  5. Oct 4, 2017 at 5:37 PM
    Dogs
    Nick
    Missouri
    02 tacoma TRD SR5
    No not just when I fill up with gas. Just anytime I turn off the truck and start it again within like five or ten minutes of it being shut off. Key-Rei, how would I diagnose it being a bad injector? And tacoma665, how do I go about cleaning that?
  6. Oct 5, 2017 at 6:23 AM
    tacoma665
    Wisconsin
    Just search on google for "how to clean an IAC valve for Toyota Tacoma"
  7. Oct 5, 2017 at 8:53 AM
    Key-Rei
    Key
    Florida
    I would definitely give cleaning your IAC and TB a go before changing a injector. As for injector diagnosis, the only difinitive method is to pull the injectors and measure their resistance with a meter set to Ohms. I don't recall the OE spec but I believe it is about 12Ω injectors 1-5 were about 13-14Ω and injector 6 was 38Ω needless to say Cyl 6 was my problem cyl. Along with the symptoms you described I also had a misfire on cyl 6 when starting warm before I finally pulled and tested my injectors.
    Start with the cheap easy fixes before shelling out for an injector though.
  8. Oct 5, 2017 at 4:03 PM
    Dogs
    Nick
    Missouri
    02 tacoma TRD SR5
    Alright, I'm going to start with the IAC valve, then I'll go from there. Thanks for the help everyone
  9. Oct 5, 2017 at 4:07 PM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    Thats a bad purge valve. Its stays open and all the fuel tank vapor fills the motor causing a rich flooded like condition. To verify disconnect the the purge line to the motor and then fill up and all will be normal once again.
  10. Oct 5, 2017 at 4:10 PM
    Dogs
    Nick
    Missouri
    02 tacoma TRD SR5
    Okay, Ill do that as well! Thanks!
  11. Oct 5, 2017 at 4:13 PM
    Dogs
    Nick
    Missouri
    02 tacoma TRD SR5
    Actually, I looked up how to do that and I didn't really find anything good on it. How do I go about disconnecting it, and where is it?
