Truck difficult to control
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1000101, Jun 3, 2019.
  1. Jun 3, 2019 at 8:52 AM
    1000101 [OP] Well-Known Member
    Jon
    Reno, NV
    2022 TRD OR DCSB
    Hi all. Looking for some potential ideas on what might be going on. Tried searching, but don't see anything too similar.
    Recently my truck has had very twitchy steering. I notice this pretty much all the time, but is very bad on rutted freeways. It tends to dart around and requires excessive steering input to maintain the lane. I was coming over Donner pass (I80 from Sacramento to Reno) and was havin a hell of time keeping in my lane. Much of the road is rutted out from truck chains n such. I had slowed to 50 mph for some sections, fearing that a ball joint was going to let go.
    The next morning I put the truck on stands and checked everything I could think of. Everything seems normal. No lose tie rods, ball joints, struts, end links, anything. Tried tire pressures of 35, 32, then 30. I then took the truck to have it aligned. Everything was in spec already, but had them set higher caster since I've read that these trucks like higher caster. It was 2 - 2.2, now I have 3.8 - 4. No improvement, so that's not it. Steering rack maybe?
    Truck is a 2017 with 16k miles. TRD Offroad, DCSB MT. Been on other road trips with it before and didn't have any issues. Made an appointment at the dealer for next week, but I haven't had the best luck with dealers around here.
    Appreciate any insight you guys may have.
  2. Jun 3, 2019 at 8:54 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did this happen all of a sudden?
  3. Jun 3, 2019 at 8:56 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    Road ruts will do that to you.
    BRFab, Grindstone, YDCtaco and 10 others like this.
  4. Jun 3, 2019 at 8:57 AM
    Jon
    Reno, NV
    2022 TRD OR DCSB
    Difficult to tell. I thought I was noticing something strange, but low speeds around town it isn't nearly as bad. The recent trip over the pass confirmed I had something going on since it was much worse.
  5. Jun 3, 2019 at 8:58 AM
    Jon
    Reno, NV
    2022 TRD OR DCSB
    I don't feel any play really. The wheel tends to pull side to side much more with bumps than it used to.
  6. Jun 3, 2019 at 8:59 AM
    koditten
    Kirk
    Central Michigan
    Any brand new concrete highways nearby that you can compare to? Those are usually poured pretty flat.
    wilcam47 and GreyBaldTaco like this.
  7. Jun 3, 2019 at 9:00 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    how is it on smooth roads at high speed?
    wilcam47 likes this.
  8. Jun 3, 2019 at 9:02 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
  9. Jun 3, 2019 at 9:03 AM
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    Did you change tires?
  10. Jun 3, 2019 at 9:03 AM
    Trowbocop
    Trowbocop Adventurer
    Nashville, TN
    03 Tacoma SR5 4x4
    Sometimes tire tread & grooved fwys cause a bit of darting. How is your tread- even, do you have cupping?
    ICU1 and RobZ9132 like this.
  11. Jun 3, 2019 at 9:03 AM
    Jon
    Reno, NV
    2022 TRD OR DCSB
    Nothing super new around here, but they aren't too bad through town. It requires more steering input to keep straight at highway speeds (60-75mph).
  12. Jun 3, 2019 at 9:04 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    It's the road.... I 80 gets bad on donner summit from truck chains.... it's even more fun when you're towing a trailer
  13. Jun 3, 2019 at 9:05 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    You need to get your alignment checked.
    Tacoma-toy, 12TRDTacoma, Sosk and 2 others like this.
  14. Jun 3, 2019 at 9:05 AM
    Jon
    Reno, NV
    2022 TRD OR DCSB
    No, still factory. About 6 or 7/32s. I rotated the tires too while I had it off the ground. No noticeable change.
  15. Jun 3, 2019 at 9:08 AM
    LameOtter
    LameOtter Well-Known Member
    Bill
    18' Tacoma SR5
    I doubt it is the road causing this. I also live in Reno and have traveled the same I80 route as far as Truckee and back recently with none of the described problems. 2018 with almost 10,000 miles on it.
  16. Jun 3, 2019 at 9:08 AM
    Spare Parts
    Southern Maine
    guess you should have gotten a sport, they like to go on pavement. But as I have learned on TW, I can not even look at dirt while in my sport. :poking:
  17. Jun 3, 2019 at 9:09 AM
    1000101
    Jon
    Reno, NV
    2022 TRD OR DCSB
    Pretty even. A little outer wear, but no noticeable cupping.
    Trowbocop[QUOTED] likes this.
  18. Jun 3, 2019 at 9:10 AM
    1000101
    Jon
    Reno, NV
    2022 TRD OR DCSB
    Ya maybe lol. I like my OR a lot. I like to go off the pavement when I can, which isn't often unfortunately.
    Noch likes this.
  19. Jun 3, 2019 at 9:12 AM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    No mods at all? This is a stock truck?
  20. Jun 3, 2019 at 9:13 AM
    Aldo98229
    Aldo
    Those OR stock tires are pretty on-road biased. So I doubt they are the issue.
    If not the road surface, the only other thing I can think of is alignment, as already mentioned.
    shakerhood likes this.
