Truck difficult to control
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1000101, Jun 3, 2019.
  1. Jun 3, 2019 at 9:14 AM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Were you in the slow lane at all? That's where it's bad, as I said from the big rigs with their chains on... it gets really bad eastbound right before the summit between kingvale and boreal... every car I have taken in the slow lane on that stretch wanders like a mfer
  2. Jun 3, 2019 at 9:15 AM
    1000101
    1000101 [OP] Well-Known Member
    Jon
    Reno, NV
    2022 TRD OR DCSB
    No mods. Nothing that would affect this anyways. I have a shell on it.
  3. Jun 3, 2019 at 9:16 AM
    LameOtter
    LameOtter Well-Known Member
    Bill
    18' Tacoma SR5
    Yes, sometimes in the slow lane when CA drivers refuse to move out of the fast lane. It is very bumpy yes, but steering is no problem.
  4. Jun 3, 2019 at 9:18 AM
    1000101
    Jon
    Reno, NV
    2022 TRD OR DCSB
    Both sides. Worse the ruts, the worse it is of course. I would chalk this up to shite roads, but I've done this pass before and others like it in the past without any issue at all. Somethin's changed.
  5. Jun 3, 2019 at 9:19 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Have you checked the bearings/hubs yet? Put the front end up on stands and wiggle each wheel with your hands. Up/down, side to side. Excessive play from a loose hub or worn bearings will cause the darting that you describe.
    knayrb likes this.
  6. Jun 3, 2019 at 9:21 AM
    Shellshock
    Iowa
    What's your tire pressure? Sounds like the issue my friend had where they were running 40-50 PSI and floated all over the road. Dropped it to 30-35 and it was like you'd expect.
  7. Jun 3, 2019 at 9:21 AM
    SLICKYINC
    SLICKYINC Well-Known Member
    West Tennessee
    2017 QUICKSAND TRDOR LB
    Stock OR tires seemed to wander around in the ruts as they got older, very noticeable too. New Generals cleared that up for me.
    AKGSD, styk and Aldo98229 like this.
  8. Jun 3, 2019 at 9:21 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    ^^^ This.
    You can even give the top and sides a tug when on the ground. Any little movement other than the rubber on the tire will be magnified on the road.
  9. Jun 3, 2019 at 9:26 AM
    1000101
    Jon
    Reno, NV
    2022 TRD OR DCSB
    Yes. Side to side, up and down. Used a pry bar under the tire to look for any movement. Maybe the dealer will see something I'm missin...
    shakerhood likes this.
  10. Jun 3, 2019 at 9:28 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Did the alignment shop reset the electronic steering? Some places dont have tools do it yet. It can cause the steering wheel to jerk if the truck doesnt think it's going straight at high speeds
  11. Jun 3, 2019 at 9:28 AM
    1000101
    Jon
    Reno, NV
    2022 TRD OR DCSB
    Currently 30. Was at 35 when I went over the pass.
  12. Jun 3, 2019 at 9:30 AM
    1000101
    Jon
    Reno, NV
    2022 TRD OR DCSB
    I considered grabbing some tires, but seemed like reaching at straws. If the dealer says all ok, i may bite the bullet and get a set. Hate to take off tires with lots of life left tho.
  13. Jun 3, 2019 at 9:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    Now that you have the caster where it should be, I suspect the toe out is still a little more than you like, even if it is 'in spec'. Spec is a broad range, and there is room to play. In the autox world street class, it's typical to run toe out on the max side of spec for more 'responsive' steering. Making it very darty at speed and even worse on rutted roads.
    You've addressed tires/rotations and had an alignment. Assuming you don't have enough miles for a worn parts issue and haven't bent/broken anything (which should have been found by a good tech anyway) that only leaves a couple of options.
    Tire pressures too high making steering light/twitchy
    Toe out a bit too much for your particular conditions.
    I found big box alignment shops horrid in doing what I wanted, they just want to get 'green lights' and roll you out. The ONLY way I'd ever use a big box shop OR a dealer was if I knew the tech personally, and knew he'd align to my request, not just a 'range'. And he assured me that the machine was calibrated on a regular basis. (Something we don't think of often).
    For my autox car I found a shop that specialized in sports cars AND had his machine calibrated on a regular basis.
    For the truck and CUV, I found a shop that specializes in trucks of all types.
    Both have done great work for me. No, they don't give 'lifetime' alignments. Yes, they cost a bit more than a big box store. I guess it just depends on if you want to be sure it's right or not. ;)
    bigmw and Chew like this.
  14. Jun 3, 2019 at 9:36 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    This happened to me when I first got my truck, the dealership put 45psi into my E rated A/T tires and the steering felt very floaty, and every little bump in the road made it feel like the truck was going to lose control.
    Shellshock[QUOTED] likes this.
  15. Jun 3, 2019 at 9:37 AM
    #35
    snozberries
    snozberries is forever trying to find a campsite
    Cory
    Martinez, CA
    2016 Quicksand
    Tires, Rack, LED bar, RTT, etc.
    All I can say is I drove on 80 a week ago and was in the slow/truck lane for a short amount of time, and it was not a pleasant time. Those grooves are deep and like to hold you - if you leave them at all, you're gonna have a bad time. Then you have certain stretches where the other lanes are paved higher so when you switch, it's a large bump.
    jetfishn and RelentlessFab like this.
  16. Jun 3, 2019 at 9:38 AM
    #36
    dirtydog57
    dirtydog57 Well-Known Member
    Colorado
    2019 SR
    My truck rides straight, but inside Eisenhower Tunnel Eastbound it wanders all over the place. It really takes me for a ride in there. I attribute it to highway grooves and chain wear from all the truck traffic.
  17. Jun 3, 2019 at 9:45 AM
    #37
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Very good point!
    Many tend to assume, since they had an alignment done, that it was done properly.
    My buddy was helping me align my truck (years ago, not a Tacoma) after hours at the dealer he worked at. After spending time to setup carefully, inspect suspension/driveline components, and make adjustments, I asked him how they can do all this work for $100, or whatever they were charging. He said "we don't!" . Now to be transparent, he did have to do some fanaggling to get some rusty tie rod ends to move.
    I think some shops take the , you win some, you lose some approach, and others give you about as much time as you pay for, or at least the tech is probably going to, if the job isn't paying him enough hours.
  18. Jun 3, 2019 at 9:48 AM
    #38
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    The scoop is designed to keep the truck straight at highway speeds.
  19. Jun 3, 2019 at 9:51 AM
    #39
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Have you found entering and exiting turns feel any different? Like a little more oversteer coming out of a turn?
  20. Jun 3, 2019 at 9:51 AM
    #40
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    There is nothing electronic to reset after an alignment.
    Amanelot[QUOTED] likes this.
