Truck difficult to control
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 1000101, Jun 3, 2019.
  1. Mar 17, 2020 at 8:42 AM
    #161
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    Sure seems like every person I've seen with my same complaint has been using the stock OR wheels too.
    AKGSD likes this.
  2. Mar 17, 2020 at 8:44 AM
    #162
    HelloMyNameIs
    You definitely seem to know more about scrub than anyone I've come across before. Thank you for explaining all of this.
    What about the above with a 1.5" lift?
    AKGSD likes this.
  3. Mar 17, 2020 at 8:56 AM
    #163
    1000101
    1000101 [OP] Well-Known Member
    Jon
    Reno, NV
    2022 TRD OR DCSB
    Thanks for the update! This is very interesting. I haven't done much with mine in quite a while. Been driving my other car most of the time and procrastinating figuring out the truck. I have the stock OR wheels on mine, too. Now I need to decide if I want to buy new tires, spacers, or both... lol
  4. Mar 17, 2020 at 9:59 AM
    #164
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Depends on SAI and caster.
    Lose SAI, gain positive scrub.
    Higher caster, lose positive scrub.
    Imagine both your upper ball joints in front of you. Now imagine the lower ball joints at 12 degrees outboard and 3 degrees forward of the upper balljoints. The 12 degree angle is SAI; the 3 degree angle is caster. This compound angle headed to the ground, is the axis about which the spindle rotates.
    SAI provides stability and negates the need for high caster for stability.
    AKGSD likes this.
  5. Mar 17, 2020 at 10:04 AM
    #165
    dansflhti
    dansflhti Well-Known Member
    Nova Scotia
    24 TRD Sport +.16 Mustang GT. 14 Street Glide
    I'm shopping around for new summer wheels now...17x8 15mm offset.
    HelloMyNameIs[QUOTED] likes this.
  6. Mar 17, 2020 at 10:06 AM
    #166
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Broken leaf spring(s)....
    Sorry, I see this is an old thread and I am not about to read 9 pages, but I have had a similar issue and I discovered a broken leaf spring.... I have had an add a leaf break as well as a main leaf.... the broken main leaf made the truck goofy to drive when hitting bumps at highway speed...
  7. Mar 17, 2020 at 10:07 AM
    #167
    splitbolt
    NW Arkansas
    What size tire?
  8. Mar 17, 2020 at 10:08 AM
    #168
    dansflhti
    Nova Scotia
    Two yrs ago we bought a low miles Mustang convertible with the same symptoms,only much worse. It had worn Pirelli P-Zero tires on it.New Good Year Eagle Sports and a toe adjustment cured it totally.
  9. Mar 17, 2020 at 10:10 AM
    #169
    dansflhti
    Nova Scotia
    265 65 17 or maybe 265 70 17.
  10. Mar 17, 2020 at 10:13 AM
    #170
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    My trd offroad used to wander all over the roads, I swapped out the stock bilstiens for trd pro fox shocks and its night and day, no longer is it like a broken shopping cart.
    Im interested to see if spacers help you as I wouldnt mind adding them to my truck too.
    AKGSD likes this.
  11. Mar 17, 2020 at 10:16 AM
    #171
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Are folks in this community trying to do too much with these trucks. I fail to understand why someone would change caster just to get a huge tire to fit. Ya Know? Sounds like you've done a few alignments in your day. Right?
    Zim
    AKGSD likes this.
  12. Mar 17, 2020 at 11:42 AM
    #172
    HelloMyNameIs
    Looks like you answered your own question.
    AKGSD and Tacman19[QUOTED] like this.
  13. Mar 17, 2020 at 12:57 PM
    #173
    splitbolt
    NW Arkansas
    Nope.
    Just a guy who got tired of 'bad alignments' and found it was a lot more complicated than "3, 0, 0".
  14. Mar 17, 2020 at 1:06 PM
    #174
    splitbolt
    NW Arkansas
    Point being, if you're using 2 different tire/wheel packages with differing scrub radius, they're dynamic toe will differ along with dynamic camber.
    The one with higher positive scrub will require more positive toe.
  15. Mar 17, 2020 at 1:13 PM
    #175
    jetfishn
    jetfishn Well-Known Member
    I make that same drive up over the Sierras going to Nevada Gold prospecting several times a yr from Calif, the cement road has wear, deep ruts up to 6" deep, from truckers 18 wheelers, and your tires just don't fit well in a worn track by 18 wheelers, I am all over the road towing my Side By Side up there. Dangerous for sure. Only way to avoid is stay in fast lane with hammer down. But thats not me I do it the hard way in the slow lane since towing SXS. I fight it all the way over. Every time. I have modified suspension with much larger dia shocks, nothing is gonna fix that wandering, the worn ruts from the semi's are wider than a Tacoma wheel width so your constantly correcting, sometime the deepest ruts will throw your vehicle radically sideways, no kidding those ruts are very deep in some areas on 80. No amount of alignment is gonna fix it. State of Calif is only one that can fix your problem, hehe.
  16. Mar 17, 2020 at 2:01 PM
    #176
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    Do you have the TRD Pro vs Stock OR offsets backwards? Shouldn't more offset should give you more track width?
    AKGSD likes this.
  17. Mar 17, 2020 at 2:12 PM
    #177
    splitbolt
    NW Arkansas
    That's true when talking about negative offsets. When talking about positive offsets the lower offset will have greater track.
    Less track~25mm<15mm<0mm <-15mm<-25mm~More track
    AKGSD and hr206[QUOTED] like this.
  18. Mar 17, 2020 at 3:16 PM
    #178
    dansflhti
    Nova Scotia
    I'm still in the stock configuration. 16x7 25mm offset.
  19. Mar 17, 2020 at 3:45 PM
    #179
    splitbolt
    NW Arkansas
    I would go 265/70/17; this adds only 6mm of positive scrub.
    A 265/65/17 would add 10mm of positive scrub.
    A 285/70/17, or similar overall diameter, would be perfect, as scrub radius would be unchanged.
    AKGSD likes this.
  20. Mar 17, 2020 at 4:14 PM
    #180
    viking15
    viking15 Well-Known Member
    Joe
    i have something similar and I have a 17OR the truck easily beers to the left going highway speeds. It maybe because I have 36 in my tires BF KO2 or maybe I need an alignment. This only happens on the highway. Hope you find the problem
