Truck doesn’t like starting when warmed up
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98_3RZ_NIC, Jul 6, 2023.
  1. Jul 9, 2023 at 8:10 PM
    #41
    98_3RZ_NIC
    98_3RZ_NIC [OP] Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    Im gonna have to check clearance this week sometime and go from there. I’ll keep you posted.
  2. Jul 10, 2023 at 11:50 AM
    #42
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I'd suggest using the angled feeler gauges when you do so. Also check the little nut and bolt that holds your feeler gauges together (in a set), tighten it up before using them. My feeler gauge set fell apart in my hand and the little tiny nut dropped down on top of one of the valves. Spent a couple hours trying to fish it out lol
  3. Jul 10, 2023 at 2:18 PM
    #43
    98_3RZ_NIC
    thank you for that info! I’ll make sure I do that first.
