truck doesnt like wot from a stop
Discussion in '1st Gen. Tacomas (1995-2004)' started by mackattack07, May 19, 2012.
  1. May 19, 2012 at 9:28 PM
    mackattack07
    mackattack07 [OP] Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    OK today I just had to change out my rear main seal 3.4 prerunner auto. It jumped out of drive and into neutral when I floored it from a dead stop. It has done it once or twice before in the mud but never before on pavement. The next time I floored it it made four banging noises with hard shakes but then went rather than the usual breaking loose of tires any thaughts.and yes everything is tight and put back exactly as it was before.
  2. May 19, 2012 at 9:30 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    You check the fluid level
  3. May 19, 2012 at 9:34 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Axle wrap? :rolleyes:
  4. May 19, 2012 at 9:37 PM
    mackattack07
    william
    Fluid is good and how would axle wrap make it poo into neutral rather than spin
  5. May 19, 2012 at 9:51 PM
    mackattack07
    william
    OK I checked all the mounts before reinstallation granny seemed alittle to easily flexed but no rips and do not have a body lift only a spacer in front and rear.and this truck has towed the doors off of hell its whole life.
    It will also pop out if turning and hit a big bump like pulling onto a paved road from dirt and its just shy of 350000
  6. May 19, 2012 at 10:04 PM
    mackattack07
    william
    no fluid was black when i got the truck from my dad and had never been changed at a little over 290,xxx so i changed it and the filter everything since then the fluid is still red and smells normal
  7. May 20, 2012 at 12:28 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Goddamn. Thats a resiliant trans. I wonder if it the oil was ever changed in that first 290k miles? If not its amazing its still going. Did you get it flushed or drained? Is this a manual or an auto? Sorry not 100% sure what a main seal is
  8. May 20, 2012 at 10:52 AM
    mackattack07
    william
    Did it again today under normal acceleration crossing a highway with a hump
  9. May 20, 2012 at 9:28 PM
    mackattack07
    william
    Bump for help. What keeps the tranny in drive?
  10. May 20, 2012 at 9:35 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Sounds like what other have said before: shifter linkage.
  11. May 21, 2012 at 11:39 AM
    mackattack07
    william
    Is there a specific adjustment I just put the bolt back where it was is there a how to for adjustment
