Truck doesn't start right away. Get "Check Charging System"
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Slapsh00ter4, Feb 23, 2016.
  1. Feb 23, 2016 at 1:07 PM
    Slapsh00ter4
    Slapsh00ter4 [OP] Well-Known Member
    2016 Inferno DCSB TRDOR 6MT w/ Tech & Tow (Sold 7/3/19)
    I've had the truck 2 days. Both mornings when I go to start her up, the ignition will not turn over for like 20 seconds, and I get the "Check Charging System" message on the display. After a few tries to turn the ignition, it eventually starts and everything is fine. This also happens when I get off work to go home. It seems that after sitting for a few hours, the truck doesn't want to start right away. Is anyone else having this problem? The truck drives great otherwise. Should I take her back to the dealership?
  2. Feb 23, 2016 at 1:09 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    I'd take her back and let the dealer check it out under warranty.. Just my $0.02
  3. Feb 23, 2016 at 1:09 PM
    DanielTaco
    DanielTaco Well-Known Member
    Daniel
    Iceland
    2016 Tacoma DCSB TRD OR 3.5
    Check charging system comes on anytime the ignition is "on" but the truck not running, so that's unrelated. This is the key start I'm assuming because it's a MT. Are you pushing the clutch all the way? Have you tried it with the clutch cancel switch on to see if that makes a difference?
  4. Feb 23, 2016 at 1:13 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    I would check the charging system. If that doesn't work, I would bring it back to the dealer.
  5. Feb 23, 2016 at 1:15 PM
    Slapsh00ter4
    Clutch is definitely all the way in. And the truck eventually starts, after about 4-5 tries. It's a bit frustrating.
    TRD-Troll and PvilleJohn like this.
  6. Feb 23, 2016 at 1:18 PM
    DanielTaco
    Daniel
    Iceland
    My thought is try it with the clutch cancel switch on, if it works fine with that switch pushed you've narrowed the issue down to the clutch start system. When you say it's not starting, I'm assuming you mean it's not turning over at all, no sound from the engine whatsoever, and then all of the sudden back to normal?
  7. Feb 23, 2016 at 1:19 PM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Is the brake depressed as well as the clutch? My old manual Chevy was like that - had to have both pedals. I know my AT won't start without the brake depressed.
  8. Feb 23, 2016 at 1:24 PM
    DanielTaco
    Daniel
    Iceland
    That's only if push start equipped. He should be able to start it with just the clutch in, or with no pedal action if the clutch start is cancelled.
  9. Feb 23, 2016 at 1:24 PM
    Slapsh00ter4
    Not sure if it's needed, but I do this anyway out of habit, so yes.
  10. Feb 23, 2016 at 1:26 PM
    Slapsh00ter4
    No sound. No clicking. Just lights/power, hence the warning message. I'll try the clutch start cancel later tonight after she's sat a while to see if that solves it.
  11. Feb 23, 2016 at 1:28 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Auto won't start without brake depressed?!
  12. Feb 23, 2016 at 1:28 PM
    DanielTaco
    Daniel
    Iceland
    If you have push button...
  13. Feb 23, 2016 at 1:29 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    I've seen one where one of the fuses was loose. Can't remember which one, but it was smart key and randomly it wouldn't start, you would push the button and nothing would happen, just stay in the key on position. Just pulled the fuse that was causing the issue and tightened the tension where it goes and it was all good.
    Edit: it was the engine bay fuse block
  14. Feb 23, 2016 at 1:29 PM
    CaptAmerica
    Cap
    All push-start Toys are like that. My wife's Prius and in-law's Highlander are the same. Pressing start without the brake engaged goes into accessory mode, and does not engage the starter.
    PvilleJohn likes this.
  15. Feb 23, 2016 at 1:31 PM
    T4RFTMFW
    Good lord.
    12TRDTacoma and angry john like this.
  16. Feb 23, 2016 at 1:53 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Could be a dead spot in the starter motor
  17. Feb 23, 2016 at 2:06 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I'm no Thomas Edison but here's what I would look for. What is the voltage of the resting battery? As new as yours is it should be 12.55 or higher. Colder temperatures reduce this some. Batteries have been know to short out between cells. Next after you get it started, check the voltage at the battery while running. It should be pushing anywhere from 13.2 up to 14.0, depending on the battery discharge rate. If it's lower than 13.2 it could be alternator, voltage regulator, or even a slipping belt that isn't noisy. You aren't charging the battery with less than 13.2 volts. I'd for sure take it in under warranty.
  18. Feb 23, 2016 at 2:07 PM
    DanielTaco
    Daniel
    Iceland
    If the battery was weak it wouldn't act the way he describes. It wouldn't start at all or it would crank very slow. The problem here is the starter is not attempting to crank the engine for a few tries, then it starts normally. That points to a sensor issue more likely then not.
    Lawfarin likes this.
  19. Feb 23, 2016 at 2:12 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    It almost sounds like a connection issue. If you think you can replicate it take it to the dealer and show them and let them figure it out. Sounds like you'll have to leave it with them for a while so it's a cold start but its worth it when its a 2 day old 40k truck having issues.
  20. Feb 23, 2016 at 2:13 PM
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
    And what I would do, is 1) Make sure you are doing the start procedure correct, then once that is confirmed to be correct, 2) Call the dealer and hand them the keys.
