Truck drives strange when cold
Discussion in '1st Gen. Tacomas (1995-2004)' started by Obsessed2000, Dec 22, 2016.
  1. Dec 22, 2016 at 5:12 PM
    Obsessed2000
    Obsessed2000 [OP] Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    On my 96 with the 3.4l I've started to notice when its cold the truck gives more resistance while driving than when warm.
    For example this morning it was in the 30s and on my way to work id take myfoot off the gas and the truck would decelerate quicker than normal.
    I feels like my alignment is way off, i have bad bearings or the tires are extremely low.
    Ive checked all of the above and all is as it should be. In addition on my way home it warmed up and is back to normal. Doea anyone have any suggestions or had anything similar?
  2. Dec 22, 2016 at 5:15 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    moisture in the diffs ?
    when the last time you drained and filled diffs and transfer case ?
  3. Dec 22, 2016 at 5:16 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sticking front caliper, maybe
    cruxofthebisquit likes this.
  4. Dec 22, 2016 at 5:16 PM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    Less than 1k miles when i swapped out the suspension.
  5. Dec 22, 2016 at 5:18 PM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    Caliper also has less than 1k miles on them. Not saying to rule it out yet but unlikely. Also would temp change have an effect on whether it was sticking?
  6. Dec 22, 2016 at 5:19 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    sticking rear brakes ? those rears have pivots which seize up
  7. Dec 22, 2016 at 5:20 PM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    That is one section I did not mess with. Ive been dreading having to open the drums up though.
  8. Dec 22, 2016 at 5:25 PM
    Roadeater
    Roadeater Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    Sticking parking brake. Try not using them after car warms up and is back to normal. Drive again next morning when it's cold and not having used it for the night. Just a suggestion :fingerscrossed:
  9. Dec 23, 2016 at 12:38 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Most often the bell cranks seize from not being used .
    I use the parking brake all the time no issues with them yet
    I have already had mud freeze and cause interesting things thaws out and falls off.
    Cold weather can cause fluids to be thicker tires to have flat spots till they warm up
    I am used to the normal for my truck so only pick up on different new things
    Thing is did you smell any hot brakes ??
  10. Dec 23, 2016 at 1:13 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    It's cold!
    I don't move to fast either:rolleyes:
    Mine gets stiff at about -10F.
    Obsessed2000[OP] likes this.
  11. Dec 23, 2016 at 2:19 AM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    This... Hasn't happened to me in my Tacoma, but I have a ford escort that any time it's below freezing the parking brake will freeze on, not enough to lock the tires up, but enough to cause serious resistance for a few miles. That's the first thought I'd have
  12. Dec 23, 2016 at 3:27 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    my 99 4runner did this when the park brake bell cranks seized
    the brakes stuck and it ran like I was in part time 4wd when
    starting out. once down the road and the brakes got hot (but not burning so I could smell it)
    it ran much better.
  13. Dec 23, 2016 at 7:20 AM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    No smell at all. My work is only ten miles up the road so it doesnt get a whole lot of time to warm up. Enough though to smell some burning brakes though.
  14. Dec 23, 2016 at 7:27 AM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    Only issue with this theory is i have an auto and rarely ever use the e brake/parking brake. Thanks for the idea though.
  15. Dec 23, 2016 at 8:21 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    it's easy enough to check
    crawl under there and see if you can move them
    by yanking the cable or move by hand
    if you cannot make them move by direct touch or
    yanking cable...they are geetered
  16. Dec 23, 2016 at 10:06 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Geetered ??
    I need to learn the meaning of a new word always looking to expand my vocabulary
    ThunderOne likes this.
  17. Dec 23, 2016 at 12:47 PM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    :rofl:
    Geetered
    A condition that appears when one is high as hell on Methamphetamine. It usually peaks after being high and awake for two or more days. Much like OCD but drug induced the subject will become intensely focused on tasks such as cleaning, organizing and reorganizing their belongings, "fixing things" that are not broken, and masturbating to pornography. Sometimes these tasks will take place simultaneously and continue for days. The geetered party will move around quickly from project to project in a back and forth jerky motion much like a chicken pecking in a barnyard sometimes talking to themselves or making strange clucking/whistling noises. The condition is not permanent and can be reversed with a nap, a meal and a few days rest.
    But yea...It moves just fine. Checked on it about an hour ago. But it is warm right now so it was rolling just fine.
    Fellas I think I'm gonna chalk this one up to one of those mysteries that don't have a solution and just be pissed at the cold that much more lol.
  18. Dec 23, 2016 at 2:10 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Learned something new
  19. Dec 23, 2016 at 3:09 PM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    I know right. Although that's one of those things I could have gone without knowing lol.
  20. Dec 23, 2016 at 3:26 PM
    1988Mercedes
    1988Mercedes Well-Known Member
    CHARLES
    ARKANSAS
    2020 AG PRO MT
    Is your transmission shifting into high gear when cold?
    That would cause the drag when off the gas.
