Truck feels heavy after new tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bokshi, Dec 21, 2021.
  1. Dec 21, 2021 at 7:20 AM
    bokshi
    bokshi [OP] Active Member
    Maryland
    2019 TRD Sport
    I have a 2019 Tacoma TRD sport 4 dr. I put a 3 inch lift kit when I first got the truck, but kept the original tires on since they were brand new. I just replaced them with Cooper Discoverer.
    I went from 265-70-17 to 285-70-17. The they had to put in 1.5 inch spacer so the tires not rub while driving or turning and all is good. But, I noticed that the truck feels like if I have one foot on the breaks or something. Heavy that the transmission down shifts easy when I have to accelerate.
    Is this normal?
    Thanks!!
  2. Dec 21, 2021 at 7:23 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Most likely normal. The increase in tire weight, and the larger diameter make a big difference.
    bokshi[OP] likes this.
  3. Dec 21, 2021 at 7:24 AM
    TheColoradoAthlete
    TheColoradoAthlete Well-Known Member
    Colorado, USA
    2020 DCSB TRD OR
    You’ll have power loss with larger tires, but shouldn’t feel like you have significant resistance. Does the truck stop a lot quicker if you’re just rolling at 10mph and let off the gas with no brake? Smell anything burning? Hear any metal grinding/friction while driving?
  4. Dec 21, 2021 at 7:24 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Yes.
    You added weight with the wider tires and the spacers.
    philth likes this.
  5. Dec 21, 2021 at 7:25 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  6. Dec 21, 2021 at 7:27 AM
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Elka 2.5 w/ DSC RCI Skids AP Expedition Leafs Leer 180
    Depending on which tires you went to/from, you likely added 15-20 lbs per wheel.
    Rotational mass is the worst kind of mass addition from an acceleration stand point. A regear will fix some of that, if you want to spend a couple more thousand on it...
    BudFriendguy and 71tattooguy like this.
  7. Dec 21, 2021 at 7:31 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I didn't really notice any performance loss when I jumped up from my stock O/R Wranglers to 285/70/17's but I went with Volks and NRG's - only added about 7lbs per corner. If you added significant weight with the new setup you'll definitely feel it. Might want to get the alignment checked as well to make sure you aren't toe'd out with the new setup causing drag.
    With those lift and tire specs you will be best suited with high caster UCA's and have the caster pushed forward to about 4 degrees. Was able to get properly aligned with my JBA HD high casters and the truck drives fantastic.
  8. Dec 21, 2021 at 7:32 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Oh my!
    On a Sport too?
    I'm a long way off from a lift...at least 2 years.
    Maybe I'll just go without a lift and go up one size...265/65/R17 to 270/65R17, get beefier tires and remove the splash guards.
    Thanks for the heads up on your results.
    E
    EDIT: tire calculator
  9. Dec 21, 2021 at 7:33 AM
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    Read up on the moment of inertia for a ring and you'll see why!
  10. Dec 21, 2021 at 7:35 AM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Science!
  11. Dec 21, 2021 at 7:38 AM
    Jackie Moon
    CO
    2021 DCSB OR 6MT
    She blinded me with it!
  12. Dec 21, 2021 at 7:39 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    lol
    sdshack likes this.
  13. Dec 21, 2021 at 7:39 AM
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    In addition to the extra weight and tire rolling resistance, the larger diameter affects the driveline gearing. The engine needs to work harder to get the truck moving and to keep rolling. Changing axle gears to lower gearing will alleviate the problem, but it is an expensive job.
  14. Dec 21, 2021 at 7:44 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You got the E rated tires, didn’t you?
  15. Dec 21, 2021 at 7:45 AM
    tcjacado
    tcjacado Well-Known Member
    I would also make sure that the rear brake cable is not stretched real tight after putting on the lift.
    Hobbs, Tacospike, GSDLVR123 and 4 others like this.
  16. Dec 21, 2021 at 7:49 AM
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    I changed from the stock Firestones to Coopers and the same sensation happened on mine. You'll get used to it. I run higher air pressure to compensate a bit for it and it does help on the mpg as well.
  17. Dec 21, 2021 at 7:49 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    now ya gotta regear and get a supercharger. Might as well snag a snorkel while you're at it.:santa2:
    :spending:
    Tocamo, Squirt, Watkinseli91 and 3 others like this.
  18. Dec 21, 2021 at 7:51 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Not only did you go with heavier tires but you went with larger tires, on a V6 vehicle. Yes it is normal lol.
    bokshi[OP] and Mr-Paul like this.
  19. Dec 21, 2021 at 7:59 AM
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    Don't forget to wear speedo's. Jeans, jacket, long sleeves and boxers are lots of extra weight.
  20. Dec 21, 2021 at 8:10 AM
    bokshi
    Maryland
    2019 TRD Sport
    Driving on lower speed and so on. I do not feel any differences only when on freeway going above 70 and the road is not flat. I feel like when I try to speed up the slightest it down shifts. I am good with it and I can get used to it. Just wanted to be sure it was part of the upgrade.. to which I love it.
    Thank you everyone, for the smart advice to the funny one. You guys rock!!
    rsimi72 and 9th like this.
