Truck feels low on power when accelerating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dylan L, Jul 27, 2021.
  1. Jul 27, 2021 at 9:04 AM
    Dylan L
    Dylan L [OP] Member
    2014 Tacoma TRD Off-Road
    About a month ago I started feeling that my truck felt as if it was running with half its power. When pressing the gas normally like I used to be able to do in order to get up to speeds in somewhat reasonable time, I find myself now having to put the pedal almost to the floor in order to get anywhere. I took the truck to the shop and they said that the ignition coil in the third cylinder was bad so they replaced it. I thought that should fix the problem, but I still have to step on the gas hard to accelerate even just moderately. Any one having this problem?
  2. Jul 27, 2021 at 9:25 AM
    jburner
    jburner Well-Known Member
    2013 Tacoma TRD DCSB Black
    When were plugs changed last? MAF cleaned? Air filter plugged? All the cheap usuals checked first?
    Geeves77 and Gunshot-6A like this.
  3. Jul 27, 2021 at 10:12 AM
    Dylan L
    Dylan L [OP] Member
    Don't think the sparks were changed in a while. And I am not sure when the MAF was cleaned, if ever. Air filter is not clogged.
  4. Jul 27, 2021 at 10:22 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Plugs. First thing!!!
    Then MAF very well
  5. Jul 27, 2021 at 12:21 PM
    Dylan L
    Dylan L [OP] Member
    Have an appt to get plugs replaced today. Lets hope this fixes it.
