Truck gets “stuck” in gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SixtyDashOne, Mar 13, 2018.
  1. Mar 13, 2018 at 7:50 AM
    SixtyDashOne
    SixtyDashOne [OP] Well-Known Member
    Toms River, NJ
    2007 4x4 Regular Cab
    hey guys. This happened to me 2-3 times iver the past 2-3 months. Happens randomly and have no idea what it is. Usually it happens when the truck is parked.
    Ill have the truck (manual 2007 4x4 regular cab) in gear, and go to drive and it starts to rev, but seems like the wheels are locked up and doesnt move. 2 of the 3 times i just revved it and it eventually started moving but just seemed like somebody was holding the ebrake and then just let it go. The 1 time I literally had to turn the engine off and turn it back on and it drove away fine. Any ideas?
  2. Mar 13, 2018 at 8:06 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    Black Taco '12 4x4
    Delay wiper mod. "Access" Tonneau cover. BedMat.
    Are you using your E brake or keeping it off when parked?
  3. Mar 13, 2018 at 8:20 AM
    SixtyDashOne
    Toms River, NJ
    yes i use the ebrake when parked.
  4. Mar 13, 2018 at 8:26 AM
    Canufixit
    New England
    Black Taco '12 4x4
    Any chance there is water in the Ebrake cable and it's freezing/seizing? How many miles on the clutch/pressureplate?
  5. Mar 13, 2018 at 8:41 AM
    rjbiii
    rjbiii Alleged Member
    Robert
    SATX
    '09 ACLB 5spd PreRunner & '13 DCSB 6spd 4x4
    '09 hard taco & '13 soft taco
    Next time your out driving it, stick it in 5th gear whenever youre driving pretty slow 35-45 mph and floor it. See if it lugs down or if the revs jump up. If the revs jump up, then its your clutch starting to slip. If it lugs down, then id guess the problem isnt your clutch, but something to do with the brakes
  6. Mar 13, 2018 at 9:08 AM
    SixtyDashOne
    Toms River, NJ
    not sure about the ebrake. 40k on the clutch
  7. Mar 13, 2018 at 9:09 AM
    SixtyDashOne
    Toms River, NJ
    ok thanks I can try this. I have a silly suspicious that it is the brakes also.. just not sure how I can find out for sure
    rjbiii likes this.
  8. Mar 13, 2018 at 9:11 AM
    rjbiii
    Robert
    SATX
    No problem, with 40k on the clutch, im almost 100% sure its not that, unless you are verrrry hard on it, or you got a defective luk unit. Ive read a few things about the luk clutches failing prematurely, so that could also be it..
  9. Mar 13, 2018 at 12:34 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    If it was me, I would stop using the ebrake for a while and see what happens.
    rjbiii likes this.
  10. Mar 13, 2018 at 12:47 PM
    SixtyDashOne
    Toms River, NJ
    The one thing that makes me skeptical of the ebrake is the first time it did it, the ebrake wasnt used that day
    bluezzy likes this.
  11. Mar 13, 2018 at 12:48 PM
    SixtyDashOne
    Toms River, NJ
    At 40mph , after going from 2nd to 5th, held solid at 1500rpms. Clutch feels fine
    rjbiii likes this.
  12. Mar 13, 2018 at 12:49 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Wasn't used at all? or only used once?
    What have been the temps when this happens?
    I'm guessing it's freezing/sticking brakes.
    Hadataco likes this.
  13. Mar 13, 2018 at 12:49 PM
    bluezzy
    Monty
    Eugene, Oregon
    yah, then disregard my previous post.
  14. Mar 13, 2018 at 12:50 PM
    SixtyDashOne
    Toms River, NJ
    As in i was driving out of a parkinglot, and stopped at a stop sign, and all of the sudden, i thought the tranny locked up. Wouldnt move. But went in gear and freereved.
  15. Mar 13, 2018 at 1:33 PM
    Canufixit
    New England
    Black Taco '12 4x4
    I have had in the past a drum brake bonded (adhesive) lining separate from its shoe. It floated in place next to the shoe, but every once in a while the lining would get moved and pinched/wedged between the the other shoe's lining and the drum - causing the wheel to lock up. I had to pull the drum to find the problem. I just replaced the shoes and all was well ...
    rjbiii likes this.
  16. Mar 13, 2018 at 8:23 PM
    95 taco
    95 taco Battle Born
    Intereting, it sounds like you have either a spring return issue or another cause of binding.
  17. Mar 13, 2018 at 8:39 PM
    b_r_o
    b_r_o You're gonna have to speak up, I'm wearing a towel
    2015 DCLB
    Remove drums, clean/inspect/adjust shoes as needed. You can dab a little grease on the shoe/backing plate contact points by gently prying the shoes away from the backing plate with a small pry-bar
    Blockhead likes this.
  18. Mar 13, 2018 at 8:47 PM
    Nalex
    Nalex Well-Known Member
    2012 Tacoma DC TRD OffRoad
    If the the ebrake is stuck it would stall and not rev up. If it is revving up but not moving it is the clutch. If the clutch is not installed right or you don’t know how to drive it properly it can go bad quickly
  19. Mar 14, 2018 at 4:14 AM
    SixtyDashOne
    Toms River, NJ
    I am quite well versed in driving manual for over 30 years. Never blown a clutch in over 25 road sorthy vehicles. im 99.9% sure its not a transmission issue
    Btw why would the ebrake being stuck on a manual vehicle not allow a vehicle to free-rev? Lol
  20. Mar 14, 2018 at 4:14 AM
    SixtyDashOne
    Toms River, NJ
    Yeah it seems very odd to me as well
