Truck groaning in reverse
Discussion in '3rd Gen. Tacomas (2016-2023)' started by boston23, Dec 1, 2022.
  1. Dec 1, 2022 at 3:14 PM
    boston23
    boston23 [OP] Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Title pretty much sums it up.
    The truck starts making a groaning noise after i shift in reverse. Backing up and while stopped holding the brake. Noiss stops as soon as I shift out of reverse. It sounds sort of like when your disc brakes are dirty so they groan for a while.
    Happened after I fluid filmed the undercarriage and installed reinstalled my T case skid plate…
    Not sure what it could be.
    any ideas?
    thanks guys,
    Adam
  2. Dec 1, 2022 at 3:39 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It’s hunger pains. Feed your truck.
    Hogleg918 likes this.
  3. Dec 1, 2022 at 4:08 PM
    mrengineerical
    mrengineerical Well-Known Member
    Baltimore, MD
    2019 Tacoma TRD Sport DCSB
    Maybe low transmission fluid on a low temp start up? I had weird transmission shifting issues during cold mornings that went away when the fluid heated up. Found out I was low a quart on fluid.
  4. Dec 1, 2022 at 4:22 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Sounds like a dragging parking brake. Did you disturb the parking brake cables?
    shakerhood likes this.
  5. Dec 1, 2022 at 4:38 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Well, if we just go by the "deltas" that you mentioned; I would not think spraying fluid film on your undercarriage would cause any sort of binding or sound issues. So I would lean towards the skid removal / re-install being the culprit. But even then I don't know! Previous comment on your parking brake cable might be worth looking into.
    bulalo and Stocklocker like this.
  6. Dec 1, 2022 at 8:10 PM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    That’s probably it, i had to sandwich on of the skid’s mounting plates between the brake cable bracket and the frame
    any idea on how to fix it?
  7. Dec 1, 2022 at 10:23 PM
    Stocklocker
    17TRDORDCSBAT
    Are the cables still kinked or bent by the skid plate after the install?
    There is some sort of turnbuckle adjustment that loosens both cables located inside your center console. I’ve never seen this first hand, but had a similar problem with my parking brakes after a lift. The Toyota spec is “7 clicks” until the handle is firm for the parking brake, according to the Toyota mechanica who diagnosed my problem. If you have less than this, or the handle feels loose, you may be binding your cables, or it could be something else entirely.
    When I had my issue, the handle was only 3-4 clicks until tight.
    boston23[QUOTED][OP] likes this.
  8. Dec 1, 2022 at 10:26 PM
    Stocklocker
    17TRDORDCSBAT
    I’ll just mention as well, if you parking brake is dragging slightly, your rear wheels will always be warm from the frictional heat, even when you haven’t been hard braking.
    Let us all know when you figure out what is causing it. Hopefully this isn’t a wild goose chase looking at the brakes.
    boston23[OP] likes this.
