Truck has minor squat look
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GA Taco, Mar 31, 2018.
  1. Mar 31, 2018 at 10:47 AM
    GA Taco
    GA Taco [OP] Well-Known Member
    Atlanta, GA
    2G BSP TRDOR DCSB
    So I recently installed Bilstein 5100's all around and the front is set to 2.5". There is no block in the rear. My shop said I can either put a 1" block in rear or lower the front down to 1.75". What would be the best option? I am running 285/70R17 tires on 17x9 wheels.
    I want truck to sit level, and would prefer not using a block and lowering the shocks to 1.75". If I do this, will I scrub (right now I have zero scrub). Truck will not be used off road.
  2. Mar 31, 2018 at 10:50 AM
    GA Taco
    Atlanta, GA
    2G BSP TRDOR DCSB
    Here’s a pic
  3. Mar 31, 2018 at 10:50 AM
    GA Taco
    Atlanta, GA
    2G BSP TRDOR DCSB
    Or would block be better? Would it impact ride quality bad ?
  4. Mar 31, 2018 at 10:51 AM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    You could get an AAL to raise the back without a block.
    chiefcrunchy, lynyrd3 and Doogz like this.
  5. Mar 31, 2018 at 10:56 AM
    GA Taco
    Atlanta, GA
    2G BSP TRDOR DCSB
    I want truck to sit level. What is the best course of action to achieving this. Whether it be Block, AAL, or lowerig shocks
  6. Mar 31, 2018 at 11:01 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Blocks suck! They help you get axle wrap faster. Use an Aal!!!
    GA Taco[OP] likes this.
  7. Mar 31, 2018 at 11:02 AM
    GA Taco
    Atlanta, GA
    2G BSP TRDOR DCSB
    Ok, so any recommendations for AAL to achieve level stance with 2.5" Bilstein shocks up front?
  8. Mar 31, 2018 at 11:03 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Relax... Op unchained510 is trying to explain what a Help situation is
    Like someone is broken down or worse. Maybe a title like : My truck squats, opinions please
    tcjacado likes this.
  9. Mar 31, 2018 at 11:05 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Off hand , I'd ask @HeadStrong Off-Road
    HeadStrong Off-Road likes this.
  10. Mar 31, 2018 at 11:05 AM
    GA Taco
    Atlanta, GA
    2G BSP TRDOR DCSB
    I didn't know, but now I do. Will not make the mistake again of posting HELP in the title unless it's an emergency.
  11. Mar 31, 2018 at 11:06 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    I'm not mad, just offering future ideas.
    Looks like maybe a 1.5AAL might be a good . Headstrong offroad,, Wheelers, Icon.. Etc
  12. Mar 31, 2018 at 11:08 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    I would go for AAL as others have said.
    jeff b and lynyrd3 like this.
  13. Mar 31, 2018 at 11:12 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Also .. If you had an emergency that you needed unchained5150 would be there to help.... Great guy .. FYI
  14. Mar 31, 2018 at 11:22 AM
    GA Taco
    Atlanta, GA
    2G BSP TRDOR DCSB
    Y'all wouln't say lower the front shocks to 1.75"?
  15. Mar 31, 2018 at 11:24 AM
    REDdawn6
    Redlands CA.
    2011 Tacoma TRD 4x4
    Depends on what you want? An AAl is not hard to put in or have put in.
  16. Mar 31, 2018 at 11:30 AM
    GA Taco
    Atlanta, GA
    2G BSP TRDOR DCSB
    I want the truck to sit perfectly level with no scrubbing. I am running 285x70x17 tires on 17x9 wheels. currently there is no rubbing. i also do not go off road
  17. Mar 31, 2018 at 11:36 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I’d go with a three leaf progressive AAL pack from Headstrong or Wheelers. It will probably give you a little forward rake which is nice for when you load the bed down so you’re not sitting nose high with a sweet bro lean. Ride is a lot better than a stiff single AAL and actually gives you a useful lift unlike a block.
    lynyrd3 likes this.
  18. Mar 31, 2018 at 11:38 AM
    P51DeP
    P51DeP Well-Known Member
    Christopher
    San Jose, California
    2008 Single Cab Tacoma 4x4 Super White
    Fog Light Install, BFGK02's, Bilstein 5100's, 4x4 Armor Rear Bumper, Front and Back Light Housings(Euro Black) Sound Deadening Cabin, Tint all around.
    I went with a toytech AAL with Billy's all around. Like it but will be adding 884's.
  19. Mar 31, 2018 at 11:39 AM
    toyotakurtis
    toyotakurtis Well-Known Member
    Kurtis
    Oklahoma
    2018 Tacoma TRD OffRoad Black Manual
    Small lift, CMC, FN Pro Wheels, 285/70r17 BFGs
    You can add a heavy front bumper with a winch to bring the front down a little. But being serious. A small 1" block would be fine especially if you don't go off-roading. Make sure you leave the overload leaf on if you have a block as that will help with axle wrap. Head Strong has several options and there prices are very reasonable.
  20. Mar 31, 2018 at 11:47 AM
    GA Taco
    Atlanta, GA
    2G BSP TRDOR DCSB
    I know this may sound stupid, but what is "axle wrap"? I don't know anything about this kind of stuff.. a shop will be installing the block or AAL
