Truck has no power and hesitates...help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by JoshBovaird, Mar 12, 2014.
  1. Mar 12, 2014 at 9:53 AM
    JoshBovaird
    JoshBovaird [OP] Well-Known Member
    Sidney NY
    Trd Supercharger, Trd 7th injector, K&N drop in filter.
    So if some of you have seen my other thread about a p0325 code (http://www.tacomaworld.com/forum/1st-gen-tacomas/318388-p0325-help.html) I got that put my truck in limp mode and had a loud pinging or knocking if it got above like 3500 rpms but idles fine. So I went ahead and changed the harness and both knock sensors, did valve cover gaskets, plugs and wires, pcv valve and hose. Got it all thrown together last night and its idled good while I was cleaning up the garage. It was 4am so i was headed to bed. I go to take it out of the garage today and its still acting like its in limp mode. If i give it gas it feels like it has no power and hesitates. When I pulled the plugs out it had denso K16TR11 but the TRD 7th inj calls for a IK20 which I bought and gapped to around .040-.043. The ultragauge isn't picking anything up yet but I haven't driven it either. Could I have the wrong gap? Im gonna go try and double check all my connections. Im just bummed over this I just got the truck and fell in love with it and a month later here I am, I've already dropped close to 800 on this in the last week.
    Video of me driving it up the driveway
    http://youtu.be/MQDbsYbV8xc
  2. Mar 12, 2014 at 10:02 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Are you still running the same gas, when the problem started 10 min after fill up? (Last post)
  3. Mar 12, 2014 at 10:02 AM
    JoshBovaird
    Sidney NY
    Forgot to add in the weeks before I used sea foam and got the p0420 code for a little but it went away and a couple times I tried starting my truck It just kept cranking till I gave it some gas and it was fine but threw a TPS code I think it was I can't remember the exact number.
  4. Mar 12, 2014 at 10:03 AM
    JoshBovaird
    Sidney NY
    Yea still running the same gas I have a full tank:(
  5. Mar 12, 2014 at 10:12 AM
    na8rboy
    WI
    You might just have a bad load of gas. It's happened to me before. You said all this happened 10 min after fill-up.
  6. Mar 12, 2014 at 10:13 AM
    JoshBovaird
    Sidney NY
    Yea i drove about and hour away and it was fine all up until I got gas. Did you just drain it and refill?
  7. Mar 12, 2014 at 10:17 AM
    na8rboy
    WI
    Yes, and cleared codes.
  8. Mar 12, 2014 at 10:23 AM
    JoshBovaird
    Sidney NY
    Yea I guess I'm gonna have to try. How did you drain your tank?
  9. Mar 12, 2014 at 10:26 AM
    na8rboy
    WI
    Pump and hose into a 55 gallon drum.
  10. Mar 12, 2014 at 10:29 AM
    JoshBovaird
    Sidney NY
    Did you pull the tank?
  11. Mar 12, 2014 at 11:21 AM
    JoshBovaird
    Sidney NY
  12. Mar 12, 2014 at 11:34 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Sounds like your truck has Low T.
    Seriously, though, all this happened after a tank-up?
    Wonder if there was something else in that gas you bought.
  13. Mar 12, 2014 at 11:40 AM
    JoshBovaird
    Sidney NY
    Yea the truck was running good and it was shortly right after. What do you mean by Low T?
  14. Mar 12, 2014 at 11:50 AM
    na8rboy
    WI
    No, I didn't need to pull tank. Drained as much as I could. put 5 gallons in with gas can and some Iso-heat (red bottle) Ran it a few miles and then filled tank after that resolved problem.
    What he meant by Low T, is Low testosterone...lol.
  15. Mar 12, 2014 at 11:55 AM
    Noelie84
    Noel
    Wales, Maine
    Low T = Low Testosterone.
    It was a poorly executed joke.
    You also just replaced a bunch of electronic engine management parts; it may take the ECU a few minutes to adjust.
  16. Mar 12, 2014 at 3:34 PM
    JoshBovaird
    Sidney NY
    I called toyota and the guy told me to start at my first o2 sensor or bring it in. I think im gonna try the gas first then maybe take it in next week. I just dont trust the shops around me. He told me 85 to diagnose it but ive gotta trailer it 30min there.
  17. Mar 12, 2014 at 4:32 PM
    JoshBovaird
    Sidney NY
    Yea im gonna try to syphon it tonight if it dosent have a screen in it. Gonna throw a new fuel filter in it tomorrow. I get the testosterone now haha just been frustrated and bummed out all day wasnt even thinking anything but this truck.
  18. Mar 12, 2014 at 9:08 PM
    JoshBovaird
    Sidney NY
    Well I took the truck up the road tonight and it threw 2 codes a P0340 and P0351. Crank position sensor and Ignition coil A. Im gonna check the plugs in a few and see what happens. No go on syphoning the gas to, can I disconnect the fuel filter and pump it out the line?
  19. Mar 13, 2014 at 5:34 AM
    BamaToy1997
    Bill
    Navarre, FL
    Yes, you can. Find a suitable sized container, disconnect the fuel filter, and connect a hose from the filter to the container. Then use a jumper wire to shunt the fuel pump relay and it will pump your tank dry. Don't forget to have a 5 gallon can of fresh gas to add to it when you are done pumping out the tank. Most likely your entire issue has been bad fuel. Bad fuel can cause all sorts of problems with performance, as well as knock sensor codes, emission codes, and misfire codes.
  20. Mar 13, 2014 at 8:51 AM
    JoshBovaird
    Sidney NY
    Ok thats what i figured. Where is the fuel relay by chance, anyone know off the top of there head. I checked all the plugs and either tonight after work or tom I was gonna swap the coils around to see if the code came on. The boots on the coil were burnt a little on the ends I wanted to replace them. Toyota told me the coils came with the boots so I was thinking about just replacing the coils since the truck has 140k on it and I think they are the original.
