Truck has no power and hesitates...help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by JoshBovaird, Mar 12, 2014.
  1. Mar 13, 2014 at 11:54 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    EFI relay is under the hood, in the fuse box.
  2. Mar 13, 2014 at 10:40 PM
    JoshBovaird
    JoshBovaird [OP] Well-Known Member
    Sidney NY
    Trd Supercharger, Trd 7th injector, K&N drop in filter.
    Just ordered a fuel filter I'm gonna go pick up in the morning and my buddies gonna come help me get the tank drained before work. Hoping this will work I'm starting to get worried about having to take it to the dealership. I checked the coil a and it was getting good spark from the wire, I pulled it out and reseated it. Reset codes and gonna see how how it runs after the gas.
  3. Mar 14, 2014 at 9:35 AM
    JoshBovaird
    Sidney NY
    I got some fuel out by cranking the motor over, I couldn't figure out how to jump the relay yet. But heres what the gas looks like, I haven't seen gas in awhile but this smells super weak and looks really clear. Asked 2 other people and they thought the same thing.
  4. Mar 14, 2014 at 11:24 AM
    JoshBovaird
    Sidney NY
    I tried jumping it with no luck and its time for work. Anyone have any insight on what I'm supposed to be poking with the wires. I can get gas to pump out by cranking over. My pump isn't loud my buddy could barely hear it when i turned the key on. I can't hear it turn on when standing there and turning the key on. I started it this morning then shut it off and came back out and it wouldn't start for a little then it barley started running then it started to idle roughly with a skip almost then it idled better. Im getting baffled with this whole ordeal. If I can't figure it out by Monday I think I'm gonna have to find a trailer and tow it in.
  5. Mar 14, 2014 at 11:25 AM
    JoshBovaird
    Sidney NY
    Forgot to add it did the starting things a few times before this all happened. Id start it with my remote start then go out and start it back up because it ran longer than the allowed time and it would crank for awhile and finally start while giving it some gas then it revved up and was fine. It did it 2 times and threw a TPS code one of them.
  6. Mar 15, 2014 at 8:21 AM
    JoshBovaird
    Sidney NY
    Anyone on what to jump on the fuel relay. Would really like to get this gas out.
  7. Mar 15, 2014 at 8:37 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    PM Bama, he'll let you know. That or just pump it out.
  8. Mar 15, 2014 at 8:52 AM
    JoshBovaird
    Sidney NY
    How do I just pump it out if I could I would have I'm asking for help here. Ive got the point to jump the relay or pump it out and over tried I can't get a hose in to syphon it and i tried jump the relay with now luck. I ended up blowing the 20amp fuel relay fuse trying. My first Toyota and its no a good experience so far.
  9. Mar 15, 2014 at 8:56 AM
    na8rboy
    WI
    I wish I could help you with jumping relay. Like mentioned PM Bama, or Goggle it.
  10. Mar 15, 2014 at 9:00 AM
    JoshBovaird
    Sidney NY
    Believe me I've searched and can't come up with what I need thats why I'm asking, watched countless videos and searched countless pages. Everyone gives out terms and wire colors I don't know. Im color blind and never got into wire schematics. I have a feeling this truck is gonna be going down the road.
  11. Mar 15, 2014 at 9:03 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    For whatever it's worth... make sure the EGR valve isn't stuck open or closed and is functioning properly.
  12. Mar 15, 2014 at 9:30 AM
    JoshBovaird
    Sidney NY
    My 7th injector is where the erg valve was. But i was just looking at the 7th injector instruction and it says to gap the plugs at .032" and mine are .043" as I seen a few running when I searched. Would that make it run like this?
  13. Mar 15, 2014 at 9:54 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Correct plug gap might be a good place to start.
  14. Mar 15, 2014 at 2:49 PM
    JoshBovaird
    Sidney NY
    Ive been searching but i cant find alot on the trd 7th injector and what people are gapping them to. I see mostly .043"
  15. Mar 15, 2014 at 2:58 PM
    #35
    na8rboy
    WI
    Still think it's a fuel problem, you didn't have a problem with it till after you filled up the last time.
  16. Mar 15, 2014 at 3:09 PM
    #36
    TrdSurgie
    TrdSurgie revised
    Oahu
    Have you sent Bamatoy a message yet?
  17. Mar 15, 2014 at 3:12 PM
    #37
    na8rboy
    WI
    This... and he'll know the gap.
  18. Mar 15, 2014 at 4:21 PM
    #38
    JoshBovaird
    Sidney NY
    Yea i sent him a message im gonna mess with trying to get the gas out. If not i might call some local shops about dropping the tank for me.
  19. Mar 15, 2014 at 4:29 PM
    #39
    TrdSurgie
    TrdSurgie revised
    Oahu
    How much fuel is in the tank? If not much just let it sit there and idle
  20. Mar 15, 2014 at 5:01 PM
    #40
    JoshBovaird
    Sidney NY
    Ive got almost a full tank id say atleast 90%. I dont know how long it would have to idle haha.
