Truck Height Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by woodygg, Apr 6, 2010.
  1. Apr 6, 2010 at 7:17 AM
    woodygg
    woodygg [OP] Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    I'm in the early stages of considering a Tacoma purchase (had an 01 double cab 4x4 that i just sold - definitely getting a new one, it's just a matter of when).
    I'm planning on a 2-3" lift with a bit bigger tires - I haven't spent too much time considering which lift/size tires, etc.
    However, this my question - can some people with a similar setup measure the height of their truck? I'm trying to ensure it will fit in my garage - I don't want to park it on the street. If it won't fit, I probaby won't do the left.
    Thank you very much in advance.
  2. Apr 6, 2010 at 7:34 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Truck specs are available online at Toyota's website. Then add approx. lift with lift kit and tires of your choice :cool:
  3. Apr 6, 2010 at 7:39 AM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    right - but i want to make sure that's accurate... i don't want to calculated it to find out there's something else that is off a little (i doubt a 3" lift is exactly 3" for example) - and i think it's going to be close as to the clearance. i'd much rather have some real numbers to use as my gauge...
  4. Apr 6, 2010 at 7:43 AM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    i would go off factory specs... if sum1 gives you #'s what psi are their tires at? are the tires new or wore out? did there lift sag? low psi and wore out tires could cause a 3in difference. also how much crap do they have in the cab? gas?toolbox? mud underneath that never got washed off?catch my drift? there are to many varibles with a used vehicles #'s
  5. Apr 6, 2010 at 7:47 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Take the stock height and add 4.5 inches and that should account for tires and lift plus give you a little room for error.
  6. Apr 6, 2010 at 7:58 AM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    that's why i asked for a few people to post. i want actual numbers as well. many people here have pretty new vehicles that i'm not concerned too much about sag, etc. if you don't know, no need to respond to my post.
  7. Apr 6, 2010 at 7:58 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Typically lifts are at or below claimed height. I've never heard of them going over. Tires are usually about a half inch smaller than claimed height which would translate to a quarter inch less of truck height.
  8. Apr 6, 2010 at 9:38 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Really? Because my 1.5" Wheeler's AAL added 2 inches in the left rear and 2 1/8 inches in the right rear. Must just depend on how much the leafs were sagging before the install?
    I think the OP's correct in his approach. Get someone to do an actual measurement if you think you're going to be close. But beware that different tire brands of the same size come with different tread depths too. So add some extra head room.
  9. Apr 6, 2010 at 9:42 AM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    no need to get butt hurt. and FYI when you state (new one) does that mean 2010 or a new to you 09-08-07-06-01? i could've/would've pulled some tape for you but not when you bash my 2 pennies. have a good day
  10. Apr 6, 2010 at 9:49 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    Apparently, as you point out yourself, there is too much fluctuation out there for us to bother measuring for him. I have the same AAL as you and I got 1.5" of lift over my TSB. Did you just install the AAL? Has it had a chance to sag?
    OP, get the factory specs, add an estimated amount of lift to that number, and give yourself at least an inch of forgiveness. That's how high you can lift your truck. That's not trying to be rude. It's the truth. There is fluctuation on our trucks.
  11. Apr 6, 2010 at 1:09 PM
    05Moose
    Jim
    Well, I guess I see your point. But using a stock truck and adding measurements from the lift won't work either. Look at mine. Settling or not, if he's close and is adding exact numbers, then he's going to be very surprised when it's sitting inches higher than it's supposed to. To answer your other question, no TSB done just the AAL. And that must mean that my rear leafs were sagging even more due to age (they are supposed to be shaped like a frown right? j/k). I think you'd get a close enough idea using someone's with the same setup and adding a buffer in to account for small differences. But then the same can be said for using factory specs. Get them and add in the measurements and an extra inch for each piece you're adding just to be safe.
  12. Apr 6, 2010 at 1:32 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Op, my truck is 72" or 6'. I got 2.25" lift up front and 1" in the rear. I'm running 31.5" tall tires. Hope that helps.
  13. Apr 6, 2010 at 2:56 PM
    Vidman
    Vidman Protected by Glock
    Rick
    central Mass
    black TRD sport AC
    Not Enough
    A little over 75 " to the highest point of cab with 3" lift and 285 tires
  14. Apr 6, 2010 at 3:07 PM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    thanks to everyone for thier posts... much appreciated!
