Truck hesitates to take off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Raustinsd, May 1, 2017.
  1. May 1, 2017 at 9:41 PM
    Raustinsd
    Raustinsd [OP] Member
    2015 tacoma
    Hey there, my 2015 hesitates to take off. Engine responds like it's in neutral then kicks in and jolts. I just changed the oil and the filter. Filter is k&n hp 1002. I'm just at a loss. Initially I put 5 qts of oil in and the dipstick read that it was severely over filled. I drained it and now there is no oil coming out of the pan, but the dipstick reads its still over filled.
  2. May 1, 2017 at 9:43 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    did you wipe the stick off between checks? I always pull the stick out, wipe it with a rag, put the stick back in all the way, then pull it and read
    PackCon likes this.
  3. May 1, 2017 at 9:44 PM
    Raustinsd
    2015 tacoma
    Yup, multiple times
  4. May 1, 2017 at 9:44 PM
    Raustinsd
    2015 tacoma
    Forgot to mention it's the prerunner v6 4.0
  5. May 1, 2017 at 9:52 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Uh oh, you drained the transmission fluid and filled your engine oil with 2x capacity sounds like.
  6. May 1, 2017 at 9:56 PM
    excorcist
    Reno, NV
    DO NOT DRIVE IT as it sits do some research and re-fill the trans the proper way (or take it to a shop as it can be a little bit complicated if you aren't competent) and also do not start your engine until you drain the engine oil (will be another drain forward of the one you drained) and refill with proper amount.
    EDIT : you are checking the engine oil dipstick, while draining the transmission fluid if you are still not understanding. Just hope you didn't already do damage to the transmission
    kgarrett11 likes this.
  7. May 1, 2017 at 9:59 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Let it sit for a good half hour or so, and read the dip stick again. Tacomas pull oil up the dipstick tube when you check and so you will get oil on the dipstick from that when you recheck. If you are still showing oil, exorcist is likely correct that you accidentally drained your transmission fluid instead. In that case, follow his advice.
  8. May 1, 2017 at 10:21 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    My thoughts edzackery!
    Alexely999 and excorcist[QUOTED] like this.
  9. May 1, 2017 at 10:28 PM
    Raustinsd
    2015 tacoma
    That's exactly what I did... Fuck
  10. May 1, 2017 at 10:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Oh no not this shit again! :eek:
    As others have already stated. Stop. You have drained the transmission and doubled the oil level in the engine. Many have done this before you, so don't feel bad. The most famous was Krazy!
    Good read. https://www.tacomaworld.com/threads/halp.33318/
    Sorry krazie sj, but you are a classic and will never be forgotten.
    Villa and tomwil like this.
  11. May 1, 2017 at 10:39 PM
    Raustinsd
    2015 tacoma
    Well now that I know, how much transmission fluid do I need to fill er up?
  12. May 1, 2017 at 10:41 PM
    excorcist
    Reno, NV
  13. May 1, 2017 at 10:44 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do people that do this not notice the RED trans fluid coming out?
    or the fact that the drain plug pulled isnt even under the motor???
    either way OP dont drive it!!!!
    kgarrett11, 80schild and ABNFDC like this.
  14. May 1, 2017 at 10:48 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    I can't believe how much this happens. It doesn't make sense
  15. May 2, 2017 at 12:38 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Have it towed to a trans shop or dealer. Its a sealed trans so not easy to refill and know you did it right.
    Blockhead likes this.
  16. May 2, 2017 at 12:42 PM
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    OMG I just went back and ready the first page or 2 of the thread.
  17. May 2, 2017 at 12:44 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    How far did you drive it. BUT DONT DRIVE IT ANYMORE
  18. May 2, 2017 at 12:44 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    If you just drained the transmission pan, chances are, you only lost about 3-4 quarts of fluid. There's probably another 5-6 quarts inside of the transmission. You're probably okay as long as you don't continue to drive the truck. I'd purchase 4 quarts from the dealer and refill the transmission. There's a special procedure to check the "sealed" transmission, but it's not difficult. Just time consuming.
    Here's the link: https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/
    TxFireman and TacomaMike37 like this.
  19. May 2, 2017 at 12:44 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Just don't fill the radiator with trans fluid
    kgarrett11, JUS, SamGoingHam and 3 others like this.
  20. May 2, 2017 at 12:52 PM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    LOL, I almost did the exact same thing when I first changed my own oil; lucky that I took notice that the bolt I was about to remove was on the transmission pan. This is why I wouldn't take my truck to a local oil change shop because they will most likely make the mistake of draining the ATF. It is easy to make the mistake.
