truck idle weird after disconnecting battery
Discussion in 'Technical Chat' started by jayyyg84, Jun 24, 2010.
  1. Jun 24, 2010 at 6:22 AM
    jayyyg84
    jayyyg84 [OP] Active Member
    joe
    atomic city
    tacoKruizer
    toyo tech coilover
    so i was putting in a radio in my 03 tacoma sr5. i had disconnected the negative battery terminal to avoid any shorts or shocks. but however the next day when i was done installing and i reconnected the battery, i noticed my taco was idling kinda rough. and when gear is engaged the rpms drop really low and it idles rough. now i came up with a theory that maybe the vehicle is gonna take some time to fine tune itself(hence the computer) since the battery was disconnected. if you all think that maybe it is something else please help me, i have no cel or misfire. im stumped!!
  2. Jun 24, 2010 at 6:27 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Try disconnecting it again for a 30 seconds and then reconnect. I doubt it will do anything but it's worth a try. I would question what wires you used for the radio connections.
  3. Jun 24, 2010 at 6:46 AM
    jayyyg84
    joe
    atomic city
    tacoKruizer
    toyo tech coilover
    what would the wires with the radio install have to do with anything? but incase ur wondering i used the same wires that were in the truck to begin with. i did a google search on this n it looks like i aint in virgin territory here. this has happened to lots of people every1 has diff outcomes which sucks. but ill try disconnecting again. lets see wut happens (y 30 seconds? was that outta thin air LOL) i like u man, ur pretty cool
  4. Jun 24, 2010 at 6:50 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Typically, a capacitor takes roughly 30 seconds to fully discharge, dependant on it's size and capcitiy. Second, I have seen some people use the wrong wire before on a simple radio install. I know someone who used the wrong wire on a second gen on a CB install and when he would cue the mic, the truck would die.
  5. Jun 24, 2010 at 6:53 AM
    jayyyg84
    joe
    atomic city
    tacoKruizer
    toyo tech coilover
    i hear ya loud n clear man, but trust me, i dont many many many stereo installs and i always double check my wire work before i even install. everything was good bro. ill do wut u say and see if it works itself out. thnx again
