Truck idles high after replacing the battery
Discussion in '1st Gen. Tacomas (1995-2004)' started by patrick2wdtacoma, Sep 11, 2019.
  1. Sep 11, 2019 at 6:02 AM
    patrick2wdtacoma
    patrick2wdtacoma [OP] Member
    patrick
    1999 toyota tacoma extended cab 2wd
    got a question, i recently replaced the battery on my truck immediately after replacing the battery i cranked the truck and noticed that it is idling too high. is this connected or just a coincidence? thanks in advance for everyone's time
  2. Sep 11, 2019 at 7:01 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    What engine do you have? I have the 4cyl and there really isn't anything in the way when you remove the battery but if you were heavy handed or working too fast theres a vacuum line "close" that could have possibly been knocked off
    I'd start by looking at all the vacuum lines
  3. Sep 11, 2019 at 7:02 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    The ECU reset and maybe it may take a few miles to adjust to normal.
    G59 likes this.
  4. Sep 11, 2019 at 7:03 AM
    Abeyancer
    Jimmie
    PNW
    That's a much smarter thought than mine
  5. Sep 11, 2019 at 7:15 AM
    patrick2wdtacoma
    patrick
    I've put about 100 miles on the truck since I swapped the battery. I'll check all the vacuum lines though.
  6. Sep 11, 2019 at 10:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You do know they do idle up at start up to get the operating temperature up.
    They also idle higher when the AC compressor cycles on
    Did you not drive the truck and forgot??
    Are you getting The PO505 code?
    It stays at a High idle 1000 rpms or higher all the time??
  7. Sep 11, 2019 at 10:52 AM
    patrick2wdtacoma
    patrick
    Yes i am aware of you first two question about start up and a/c and the engine light isnt on.
  8. Sep 11, 2019 at 10:53 AM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    This is what I was thinking. Sometimes it takes a number of ignition cycles before the ECM relearns all that stuff, like the air/fuel ratio, spark advance, driving style, etc.
  9. Sep 11, 2019 at 10:56 AM
    eon_blue
    Azusa, CA
    Normal, usually mine idles low after replacing the battery but either way it'll go back to normal after the ECU adjusts.
  10. Sep 11, 2019 at 10:57 AM
    G59
    G59 Stock af
    Torres
    SoCal
    03’ Long Travel DC
    The ecu just needs to relearn idle. Drive it around for a mile or two and it'll be back to normal
