Truck inverter question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by savedone, May 8, 2015.
  1. May 8, 2015 at 2:29 PM
    savedone
    savedone [OP] Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    I have a question that has been bugging me and was wondering if anyone knows the answer. In our trucks that have the 400 watt inverter and plug in the bed the switch has two settings. 400 watts if the truck is setting still and idling and 100 watts if the truck is moving.
    My question is WHY? What possessed Toyota to go to the expense of making an automatic switch that cuts the wattage if the truck is moving? Why not just on full wattage and off?
    Anyone know the logic behind this? By the way I understand that there is a work around and I am not asking how to do that. I am simply asking is there a logical reason for the inverter to be set up that way?
  2. May 8, 2015 at 2:48 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    It's because Americans are lawsuit happy. We should be lucky Toyota allows the inverter to be active while out of park.
    Why do you think the rear view mirror is so low in the windshield?.. It's because if you leave your sunglass holder down, you can still see into the mirror. All it takes is one asshole to sue Toyota because the driver couldn't see into the mirror and a resulting accident caused injury and damage.... because the sunglass holder door was down.
  3. May 8, 2015 at 3:43 PM
    savedone
    Gerald
    Texas
    400 watts is 4 100 watt light bulbs or something pulling 3.3 amps. I doubt anything that only pulls 3 amps is all that big. If they were concerned about a large load in the back then they should not have a bed on the truck to haul something large enough to kill a person if in a wreck.
  4. May 8, 2015 at 3:44 PM
    savedone
    Gerald
    Texas
    I don't understand the correlation between the mirror, sunglass holder, and the inverter switch. :confused:
  5. May 8, 2015 at 4:43 PM
    File IFR
    Central MA
    That's unfortunate, but I can understand your confusion.
    DouginNC likes this.
  6. May 9, 2015 at 2:02 AM
    savedone
    Gerald
    Texas
    You mean more than idling would stress the charging system while running full power? :eek:
  7. May 9, 2015 at 6:42 AM
    Pigpen
    Dan
    Northwest Montana
    So a little throttle isn't doing any good when I'm winching someone else or jumping their battery? I've always done this.
  8. May 9, 2015 at 6:47 AM
    File IFR
    Central MA
    The alternator is regulated to give the battery a certain amount of voltage and not overcharge it. That's an old wives tale of revving the engine for more voltage.
  9. May 9, 2015 at 6:50 AM
    Pigpen
    Dan
    Northwest Montana
    HAHAHAHAHAHAHAHAH!!
    I've been doing this since I was a kid, helping the old man - since the 80's!
    Old dog - new trick
  10. May 9, 2015 at 7:46 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    While your alternator is regulated between 13 and 14.5 volts it does not put out full amperage at idle. Most alternators will only put out about 1/4 of their total amperage at idle. While jumping a dead battery or running a high amp load like a winch it is very helpful to run the engine around 2000 rpm so your battery isn't taking the full load.
    As far as the OP's question about the inverter, I have no idea.
  11. May 9, 2015 at 8:02 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    I think it's so you won't underpower needed electrical accessories while driving. Like the headlights and taillights. It's the only reason I can reason. :D
  12. May 9, 2015 at 4:51 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Or how about the biggest electrical draws on your truck, like the ABS / VSC modulator pump that is fused at 60A / 30A w/o VSC or 60A/ 50A with VSC) and draws a lot of power in the event it engages, and don't forget to add electric trailer brake draws of up to 15A if towing? I'd say it's all about ensuring plenty of power for the safety systems.
  13. May 9, 2015 at 4:52 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    This, exactly, though most modern alternators are still capable of producing about 50% current at idle.
  14. May 9, 2015 at 5:55 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    its likely some law. They probably dont want you powering some 400w light while moving the truck down the road.
