Truck is hard to start, shakes and strong smell of gasoline
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kang Li, Feb 25, 2022.
  1. Feb 25, 2022 at 3:34 PM
    Kang Li
    Kang Li [OP] Member
    Kang
    2016 tacoma trd sport
    nerf bars, grill, blackout badges
    Greetings everyone justed joined this group. I own a 16 taco trd sport just under 100k miles. Recently the truck is sometimes hard to start, when the truck is warm idling at low rpms at red light. It's performing unsual shakes sometimes very noticeable, the whole truck going back and forth feels like it’s going to stall out. But when driving everything is normal even reving it up. No signs of drop in fuel economy. Also a recent oil change I can smell strong gasoline when it began to pour. Brought to the dealer today, they said the battery and spark plugs are good. They mentioned something to do with fuel line pressure which they need further diagnostic. Anyone has this issue before?
  2. Feb 25, 2022 at 3:36 PM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    Fuel filter?
  3. Feb 25, 2022 at 3:41 PM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    A lot of great information from a Toyota Master Tech with over 10 years of experience. Go to You Tube and search for the "Car Care Nut". All he does is Toyotas.
    Tocamo likes this.
  4. Feb 25, 2022 at 7:37 PM
    Kang Li
    Kang Li [OP] Member
    Kang
    Ima looking into that
  5. Feb 25, 2022 at 7:37 PM
    Kang Li
    Kang Li [OP] Member
    Kang
    It could be
  6. Feb 25, 2022 at 8:07 PM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    I assume you had the crankshaft recall issue repaired? That is a very old recall from 2016, but checking just in case.
    Toyota replaced the faulty crankshaft sensor with a new one, that lo and behold works.
    Failing crankshaft position sensor can affect idle, acceleration, cause stalling, misfires, vibrations etc.
    If you are not sure, have your dealer take a look at it or the vehicle repair history to make sure it was changed back in 2016.
    Fuel pump can also cause the issues you are having.
  7. Feb 25, 2022 at 8:11 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Sounds like the spark plugs to me, were they ever changed
  8. Feb 26, 2022 at 6:12 AM
    RatDaddy
    Roy
    None
    if you have 100k miles and never replaced the fuel filter it may likely be that with all the dirty fuel there is. That plus old spark plugs as another mentioned could certainly be giving you all the trouble.
    Junkhead and Superdave1.0 like this.
  9. Feb 26, 2022 at 6:29 AM
    WinterFalco
    Donald
    I agree with this.
  10. Feb 26, 2022 at 7:01 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    The fuel filter is an in tank filter and is designed to last the lifetime of the vehicle.
    shakerhood likes this.
  11. Feb 26, 2022 at 9:45 AM
    RatDaddy
    Roy
    None
    You are probably right about the Toyota fuel filter, however, this makes no sense, logically. Filters are designed to trap dirt. Dirt eventually clogs a filter. Maybe if you run 100% clean fuel, then maybe, which is impossible. But maybe toyota has figured out a way to filter our dirty fuel and still keep the filter clean.
    Junkhead likes this.
  12. Feb 26, 2022 at 9:52 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  13. Feb 26, 2022 at 9:58 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Toyota and other manufactures have been doing this for a long time. Very few filters are changed.
  14. Feb 26, 2022 at 2:49 PM
    RatDaddy
    Roy
    None
    Yeah, they are gambling on the use of fairly clean fuel.
  15. Feb 26, 2022 at 3:23 PM
    Kang Li
    Kang Li [OP] Member
    Kang
    I just checked for recalls. It looks like the truck has no open recalls. Could the crankshaft position sensor fail again even it's been done?
  16. Feb 26, 2022 at 4:56 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Sounds like a general maintenance item to me. Good luck Op.
  17. Feb 27, 2022 at 9:46 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    You misunderstood. he said the filter lasts the life of the vehicle.
    That means if the filter is done, it's time to toss the truck and get a new one. /S
    Junkhead and RatDaddy[QUOTED] like this.
  18. Feb 27, 2022 at 9:49 AM
    RatDaddy
    Roy
    None
    :rofl:
  19. Mar 8, 2022 at 7:23 AM
    Kang Li
    Kang Li [OP] Member
    Kang
    Updates on the truck. Dealer charged me 2hr of labour for diagnostics. Told me both fuel pressure regulators went bad and need to be changed. Quoted me 160 for parts and 2.5 hrs of labour to get them replaced. That's is really expensive I'm not sure if I want to bring it back to the dealer..:argue::argue:
  20. Mar 8, 2022 at 7:28 AM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    Nobody works for free. Time is money. Some people may work chepaer than others. In the end, if you need the truck, get it fixed. There are other "costs" involved.
    How much "more" will you spend trying to find someone to do the work at a lower cost, and acquire the parts...
