Truck is hard to start, shakes and strong smell of gasoline
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kang Li, Feb 25, 2022.
  1. Mar 8, 2022 at 7:35 AM
    Kang Li
    Kang Li [OP] Member
    Kang
    2016 tacoma trd sport
    nerf bars, grill, blackout badges
    I understand. I was just hoping it was a clogged fuel filter.
  2. Mar 8, 2022 at 7:36 AM
    Kang Li
    Kang Li [OP] Member
    Kang
    By searching around the forum I couldn't find a lot info regarding 3rd gen fuel pressure regulator problems.
  3. Mar 8, 2022 at 7:50 AM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    Find out what the dealer's position will be if the work they do does NOT solve the problem...
  4. Mar 8, 2022 at 7:57 AM
    Kang Li
    Kang Li [OP] Member
    Kang
    They said its a starting point. I told them I'm not paying extra if the problem persist they offered me 10% of for this visit and told me they will do their best if they don't solve the problem.
  5. Mar 8, 2022 at 8:05 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Sometimes it's a guessing game! Do you have an independent shop that you can get a second opinion from? Might be worth your time (and money) to do so.
  6. Mar 8, 2022 at 9:18 AM
    Kang Li
    Kang Li [OP] Member
    Kang
    I bought the truck a few weeks ago. You're right. I should be looking for a local independent toyota specialist just in case of any future problem.
    eurowner likes this.
  7. Mar 8, 2022 at 9:30 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    it's a stupid design and doesn't last the lifetime of the vehicle, especially when traveling to different areas. you can not control how clean the gas you are getting is..
    a fuel filter is a consumable item.
    cryptolime likes this.
  8. Mar 8, 2022 at 9:34 AM
    FishaRnekEd
    New Orleans, LA
    have you checked the entire intake?
    a slightly dirty throttle plate can cause rough idle.
    any of the flapper things in the intake can also get dirty or worn and cause rough idle
    do you have any obd codes??
  9. Mar 8, 2022 at 10:11 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Looks like the regulator is roughly $40 each on rock auto shipped. If you are mechanically inclined, you could try to change it yourself and save the money.
  10. Mar 8, 2022 at 11:52 AM
    Kang Li
    Kang Li [OP] Member
    Kang
    not at all beside I can change cabin and engine air filter lol
  11. Mar 10, 2022 at 10:18 AM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
  12. Mar 10, 2022 at 11:54 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    more like the lifetime of the fuel pump. get some good fuel injector cleaner like amsoil or redline. should clean out the fuel system as much as possible without pulling the fuel tank.
    FishaRnekEd likes this.
  13. Mar 11, 2022 at 12:30 PM
    FishaRnekEd
    New Orleans, LA
    I'm on the naptha train. LoL. i say get a can of seafoam. (anyone that thinks it doesn't work, is wrong. but it's not a miracle, fuel system cleaning agents are more of a preventative maintenance item, not a "fix")
