Truck is jumping almost always and sometimes violently :(
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1stTacoma!, Dec 5, 2023.
  1. Dec 8, 2023 at 7:43 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i took the bowl of the carb off and found rust sediment. we dont have a "bowl" on our trucks.
    the tank, i had it cleaned. no issues after that. they may have sealed it with a coating. been a long time.
  2. Dec 8, 2023 at 7:48 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you had a fuel delivery issue it would show up as high long term fuel trim readings. Like +15-20%. A weak pump, poor quality fuel, etc..
  3. Dec 8, 2023 at 8:03 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It could be your tach is working just fine.
    It goes to 0 because the ignition shuts off .the signal from the igniter is not going to your tach
    If your fuel shut off the tach would still show the rpm till the engine ran completely out of fuel and stopped.
    Steves104x4 likes this.
  4. Dec 8, 2023 at 8:11 AM
    SWPA Tacoma
    SWPA Tacoma Well-Known Member
    Stevo
    2006 White Tacoma DCLB
    I thought this might have something to do with this issue....and it may have been missed since it wasnt in the initial post.
  5. Dec 8, 2023 at 8:18 AM
    Bivouac
    Do you run junk yard gas through any added filters or direct to the tank??
    You might have poor gas and a ignition problem.
    Water and hot spark plugs are not a good mix
    How do the plugs look ??[9
  6. Dec 8, 2023 at 8:19 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Doctor, i drank a qt. Of poison. Will i get sick or die?
  7. Dec 8, 2023 at 8:52 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe try swapping the horn relay with the fuel injector EFI relay
  8. Dec 9, 2023 at 12:20 PM
    Rougarou680
    Rougarou680 Swamp Lurker
    Lousyana
    2006 Tacoma 4.0 Prerunner, 2013 & 2014 Tacoma 4WD 4.0L
    Leveling kit, hydro dipped rims & skid plate on 2013, 6” pro comp lift & color matched rims on 2006.
    Didn’t overheat or lose coolant. Burned oil though. Still getting intermittent issues like you described which makes me think it’s also fuel related. I also got all the misfire codes.
    1 Limited Toyota likes this.
  9. Dec 14, 2023 at 3:30 PM
    1stTacoma!
    1stTacoma! [OP] Onlyfans.com/death713
    K
    ‘04 4cyl 2.7L Prerunner SR5 Access Cab w/150k miles
    Who burned oil? You or me? lol im confused. Anywho, yes I agree on that of the issue being fuel related.
  10. Dec 14, 2023 at 3:30 PM
    1stTacoma!
    K
    Did that
  11. Dec 14, 2023 at 3:30 PM
    1stTacoma!
    K
    DUH! lol
  12. Dec 14, 2023 at 3:38 PM
    1stTacoma!
    K
    haven't checked the spark plugs since they were changed some years ago. but after what happened yesterday (which ill be editing into the original post in just a moment) I did put some fuel on a rag and held it up to the air intake and the car started so im like 90% sure its a bad pump. and the only "filter" I run the gas at the yards thru is a t-shirt or a rag.:der:which is really more like straining which ive just been informed that is far from efficient/sufficient. Live and learn right lol
    Bivouac[QUOTED] likes this.
  13. Dec 14, 2023 at 3:40 PM
    1stTacoma!
    K
    I feel you, but the tachometer goes bonkers even when the truck is driving fine, shifting appropriately, and at any speed.
  14. Dec 14, 2023 at 3:47 PM
    1stTacoma!
    K
    I finally got a F**** code!! :rofl:The damn code couldn't be more vague though :facepalm:.
    Code is: P0171-Fuel Trim System Too Lean
    https://www.kbb.com/obd-ii/p0171/
  15. Dec 14, 2023 at 4:03 PM
    #35
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yep, that means the system is struggling to achieve the correct mixture. It keeps trying to add fuel and add fuel but the oxygen sensors keep seeing too much air.
    Check fuel pressure, look for intake vacuum leaks, make sure all the ducting between the MAF sensor and throttle body is secure
  16. Dec 14, 2023 at 4:43 PM
    #36
    Bivouac
    Could be a poor connection that opens at times along with an ignition problem.
    So many different things can trip that PO171 code.
    One thing at a time no friends close that can help?
  17. Dec 14, 2023 at 4:45 PM
    #37
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Now that you know the cel code, it would be worthwhile to do a little research on here. There are quite a few things that can trigger that code and there are lots and lots of threads that talk about it.
  18. Dec 15, 2023 at 12:34 AM
    #38
    1stTacoma!
    K
    Fuel pressure is at nil lol. There are no vacuum leaksand all ducting from MAF to throttle body are secure and in place. I just dropped the tank (hopefully I can remember where all the damn hoses were connected)
    Yes sir. that's what im doing. And as for friends, I did get some guidance from someone whose opinion I really value and have l know since the 10th grade. I also have a friend here who helped me drop the tank and will be helping reinstall it too.
    Taking a break now while I research how to replace the fuel pump. IF anyone has any wisdom to share please feel free.
  19. Dec 15, 2023 at 4:14 AM
    #39
    Bivouac
    Depending where the truck lives a new fuel pump bracket is a great idea .
    A new fuel filter .
    If you dropped the tank without breaking anything you did good
  20. Dec 15, 2023 at 4:49 AM
    #40
    1stTacoma!
    K
    hey good morning. So I don't think I broke anything. but I may have damaged the clamp on the fuel supply hose a bit :/ besides that the tank just ways so much nice the is some gas in it and the homie that helped me drop it is passed out. not sure how ill get it back up there. can you send me a photo of te "bracket" you mentioned please? Also there is only one fuel filter correct? how often should it be changed?
