Truck is missing something- wheels/tire size?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lostcity1981, Sep 20, 2017.
  1. Sep 20, 2017 at 4:51 PM
    lostcity1981
    lostcity1981 [OP] Well-Known Member
    Recently purchased the canopy, but I feel like my truck looks a bit imbalanced- wondering if larger tires or wheels could do the trick? Currently have a 1.5 inch leveling kit on the front, but wishing I had done a 3 inch. Any advice?
    Tacomamike mike likes this.
  2. Sep 20, 2017 at 4:54 PM
    doorsidedown
    doorsidedown Well-Known Member
    Truck looks good man. Maybe a larger more aggressive tire... then perfecto.
  3. Sep 20, 2017 at 4:55 PM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    i never really cared for the roof rack. it kind of gives it the mini van look.
    the front and rear tires different?
  4. Sep 20, 2017 at 4:55 PM
    Bolsillos5624
    Bolsillos5624 Needs more money for mods
    Shannon
    2017 Tacoma Off Road Access Cab
    Bak Revolver X2 Tonneau. Cover Custom TRD Change Holder
    Would definitely look better with bigger tires/ higher lift as long as fuel mileage is not an issue to you. I'm not a fan of the bed caps either, but obviously your keeping that ;)
  5. Sep 20, 2017 at 5:37 PM
    TACTICAL TACO
    TACTICAL TACO Member
    Monte
    2017 D.C. TRD OFF-ROAD
    I think bigger tires but other than that it looks great .
    Tacomamike mike and doorsidedown like this.
  6. Sep 20, 2017 at 5:48 PM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    When will silver wheels make a comeback?
    Tacomamike mike and Lt. Dangle like this.
  7. Sep 20, 2017 at 5:53 PM
    Phoosa
    Phoosa I never saw nothing.
    Truck
    I've been in that boat before. Get bigger tires.
  8. Sep 20, 2017 at 6:00 PM
    Jaggerbub
    Jaggerbub Well-Known Member
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    Right off the bat i bought t4r and ko2's... I always thought mine looked naked without mudflaps. Then when i put them on, I thought it looked like it was missing sidesteps/rocksliders. I picked up a set of oem takeoff sidesteps on craigslist for $160. Then I started liking the side profile more. ( side note... if I did it over again, i'd get some rocksliders instead) That's what i plan to switch out soon. You'll kina see what i mean when u see these photos.
  9. Sep 20, 2017 at 6:00 PM
    NovaGTS
    NovaGTS Well-Known Member
    NOVA
    2012 TX BAJA SERIES
    I had the same problem with the cap it looks like you're having, the stock springs sag pretty bad under that constant weight...
    Also like the rack without the cap, but with the cap I think too much is going on.
  10. Sep 20, 2017 at 6:18 PM
    ICU1
    ICU1 Well-Known Member
    Black out chrome
  11. Sep 20, 2017 at 6:19 PM
    lostcity1981
    No, they are the same.
  12. Sep 20, 2017 at 6:26 PM
    lostcity1981
    Thanks! Any you would recommend?
  13. Sep 20, 2017 at 6:27 PM
    lostcity1981
    Yeah, I love the cap and need it for camping. I knew I should have gone with the 3 inch! What tires would you recommend?
  14. Sep 20, 2017 at 6:29 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Its your tires need more aggressive and one size up is all. Then think about lift. Could always lower your billies to zero and add ome 887 springs and uca's for 3" front. That lift is about 1200$ roughly. Looking good so far though!
  15. Sep 20, 2017 at 6:35 PM
    Friedtacolover
    Travis
    Ontario, Ca
    They never left always been classy.
  16. Sep 20, 2017 at 7:05 PM
    SR4x4Matt
    SR4x4Matt Member
    WV
    '16 Gray DCSB
    Bilstien5100s, Yellow fog lights, 1.5 AAL, UWS box. JBA off-road UCA's, 1.25in spacers, 255/85r16 st maxx
    I think you may need a bit more lift in the back, especially if your planning on 3" in the front. Other than that I think slightly higher and bigger tires would look great. You could always join the 255/85 skinnies club lol
  17. Sep 20, 2017 at 7:25 PM
    lostcity1981
    Thanks everyone- good to know I'm not the only one that thinks something is missing...so tire size- any recommendations? These are 265/70 Open Country's from Les Schwab.
  18. Sep 20, 2017 at 7:43 PM
    ThatOneTaco
    ThatOneTaco Well-Known Member
    CA, Bay Area
    2017 DCSB 4X4 TRD Off-Road
    I’d change out the rims and tires. You can stay with 16inch rims but maybe something wider with a better offset. Tires you just need to go a little bigger.
    Personally, I think 17inch rims would be a better look for your setup.
  19. Sep 20, 2017 at 7:53 PM
    Stiffler199
    Stiffler199 Sandy Sanderson
    2017 trd off-road long bed. All options
    Tint, bed mat, dipped grill, PIAA lights and fogs
    I'd get the crossbars and a box or wire basket for the canopy. Thats what I did. And lose those Chrome bolt on the wheels. Paint them. Then drop some aggressive AT's.
    Once you are there prepare for the second mortgage because you will only want to continue the insanity that Tacoma ownership brings.
  20. Sep 20, 2017 at 10:08 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    can you lose that roof rack?
    Bolsillos5624 likes this.
