Truck is pulling, no idea why
Discussion in '1st Gen. Tacomas (1995-2004)' started by mauibuilt41, Jul 19, 2010.
  1. Jul 19, 2010 at 6:39 PM
    mauibuilt41
    mauibuilt41 [OP] Active Member
    Maui
    02 PreRunner Dbll Cab
    Hey guys! Sorry for all the questions but I've got so many different things going on. When I purchased my truck in June it had a right hand pull. So I had it aligned and also had the tires rotated and balanced. The right hand pull is still there. My steering wheel also shakes at 60 mphThe tires are some cheap brand I have never heard of so I will replace them when the funds are available. Do you guys think it is a tire issue. I have searched the forum but found a bunch of different answers.
  2. Jul 19, 2010 at 6:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Sounds like tires.
  3. Jul 19, 2010 at 6:40 PM
    xroller
    xroller Blowin by em sideways
    Ramon
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    probably the tires....... there is such thing as a tire pull.... are they properly inflated? do they have uneven wear?
  4. Jul 19, 2010 at 6:42 PM
    jamesglynn
    jamesglynn James
    James
    Alabama
    2010 TRD Off Road, Dble Cab, Magnetic Gray
    good chance your tire are not properly inflated or they are cupping on the edges. I would think your problem is in the tires, I had the same think on my 04, I put some Michelin LTX's on there and problem solved.
    Good Luck
  5. Jul 19, 2010 at 6:48 PM
    DeedleBag
    DeedleBag Well-Known Member
    Houston, TX
    08 Tacoma TRD Prerunner
    Bilstein 5100, K&N Air Filter, Grillcraft
    Well remember, your truck should always pull slightly to the right for safety reasons. Say if you were to fall asleep at the wheel.
  6. Jul 19, 2010 at 7:07 PM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    um no. your truck or any other vehicle for that matter should drive straight. IT SHOULD HOWEVER PULL WITH THE CROWN OF THE ROAD. I also dont think it is your tires. its your brakes. your right front brake caliper is seized. it starts with the inside lower piston and then goes from there. replaced both front calipers rotors and pads and you will be good.
  7. Jul 19, 2010 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OP, You can find out if its a dragging brake, as one side will be much hotter than ther other. Feel the wheel near the hub. If its hot, its a dragging caliper.
  8. Jul 19, 2010 at 7:17 PM
    humtaco
    humtaco Well-Known Member
    right its by desegn if case yur sooo drunk you pass out yuul go into the trees insteed of oncomeng traffic.
  9. Jul 19, 2010 at 8:16 PM
    mauibuilt41
    Maui
    Well I always figured it was the tires. I know after I got them balanced, one of the tires had like 3 weights right next to each other. I'll also look into the brakes. I just wanted to make sure it wasn't a steering column issue as I have read a bunch of those on this site.
  10. Jul 20, 2010 at 8:54 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Jack the wheels. If it turns hard=bad brake. Use temp gun, it will show the differance better. $30 from sears. You can also find cold spots in radiators, ac temps, etc.
    If tires wear from a bad alignment, they will not run true anymore. Same can be said for out of balance for too long.
  11. Jul 20, 2010 at 9:20 AM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    I had similar problems when I got mine. It had unevenly worn BFG ATs and had a very hard pull to the right (If I let go, it would happily and immediatley head straight for the ditch), but clearly had needed an alignment for some time.
    I bought new Michelins and had an alignment. Problem mostly solved, but then I had the classic 60 mph vibration, which is from bad (meaning incompetent) wheel balancing, probably a static balance. The 1st gen aluminum wheels are a little notorious for being tricky to balance, and a lot of people will say road force balance them, or use the Hakewa adpater, but I found a great shop who could just do it on a regular dynamic balancer without any of this. Find a reputable shop and buy some good tires...
    And they will need to use clip-on weights on the outside, not the adhesive weights that they try to hide inside the wheel (right behind the spoke area).
    All this assuming you don't have a hanging brake caliper....
