Truck is rattling and drinking coolant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UncivilBeast, Sep 28, 2021.
  1. Sep 28, 2021 at 11:37 AM
    UncivilBeast
    UncivilBeast [OP] New Member
    Brennan
    09 toyota tacoma 4cyl
    I have an 09 toyota tacoma base model 4cyl. It has run mu coolant from topped to empty in less than 2 weeks light driving back and forth to work. It makes a weird rattle when I left off gas. And it has also taken a bit of oil since my oil change recently. It has a good amount of oil, but the red light appeared even though there is oil.
    Also, it has a lag from a stopped position to when I press gas for it to pick up.
    Let me know what you guys think, I'm buying a head gasket tester. To see if that's the issue but I don't believe so if it's drinking coolant so quick.
  2. Sep 28, 2021 at 11:43 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    And you have no leaks, hoses etc…
    Do you have milky crap on your dip stick
  3. Sep 28, 2021 at 11:43 AM
    Waasheem
    Waasheem
    2007 xrunner
  4. Sep 28, 2021 at 11:48 AM
    UncivilBeast
    Brennan
    No leaks, hoses are solid. And nothing milky in my coolant res (considering empty but was never like this prior) or in dip stick
  5. Sep 28, 2021 at 11:52 AM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Quick and easy test is. If the radiator is full. Take the cap off. Start the truck and watch for bubbles. If you see bubbles you have a head gasket issue.
    06Tacooo likes this.
  6. Sep 28, 2021 at 12:09 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Pressure test the cooling system. See if there is a failure somewhere
  7. Sep 29, 2021 at 8:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would be more concerned about the red oil pressure light as well as the loss of coolant.
    Loss of coolant, loss of oil, oil pressure light coming on and rattling in the engine = serious engine problems to me.
    I wouldn't drive it until I find out more information.
    Dm93 and tacomataco2 like this.
  8. Sep 29, 2021 at 8:14 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    X2 if the oil pressure warning light is on don’t drive it
