Truck is running really bad... Misfire...
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99GreenYota, Dec 21, 2009.
  1. Dec 21, 2009 at 4:38 PM
    99GreenYota
    99GreenYota [OP] Well-Known Member
    Dan
    Devner, CO
    06 Tacoma V6 TRD Sport
    To many to list...
    I would like to say that I am new here, and its nice to meet everyone! But I do have a question as well...
    I have a 99 toyota tacoma 4x4 V6 with about 170,000 miles on it. The other day I went on about a 200 mile drive and the truck ran fine for the drive. We then stopped to eat lunch, (turned truck off for about 30 mins) got back in, started it, and ran, but was shaking really badly. Engine light came on shortly after that so I took it to get checked... said it had a Cyl. 4 misfire. The guy said check the plugs, they may be bad. I had just changed my plugs probably 6 months ago, with the stock toyota plugs. but checked them and they were fine. Then we tried changing the plugs wires, and the Cyl. 4 Coil on plug thingy for Cyl. 1 and 4. Still nothing is better...
    Now here is the thing, when cold the truck starts fine, runs and will run normally till it gets warmed up, I have stopped and re-started it. Sometimes it gets over it, and runs normally. Thought it might be bad gas, but run sea foam through the tank and filled it up with different gas and ran that through. Still not better...
    Anyone have any better options?
    Thanks, Dan
  2. Dec 21, 2009 at 4:48 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    have you done seafoam through the brake booster? worth a shot!
  3. Dec 21, 2009 at 4:51 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    x2
  4. Dec 21, 2009 at 5:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    could be a fuel injector....
  5. Dec 21, 2009 at 5:56 PM
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    Brake booster? Unless i'm not sure what that is, its not really a problem happening with the brakes, but if it has another purpose, could be...? And with the injectors, thought about that as well, but the purpose of the sea foam was to clean the injectors...
    Dan
  6. Dec 21, 2009 at 9:19 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    He's talking about the vacuum line that feeds the brake booster. You feed the Sea Foam through it so it can clean stuff out.
  7. Dec 21, 2009 at 9:24 PM
    Justin723
    Justin723 Dont judge me
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- Trail Gear Solid Axle Swap, ARB compressor, high pinion 4.88 with ARB locker, 4.88 TRD Locker in the rear. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, and Weather Tech floor mats.
    You pore the Seafoam in your PCV valve is what hes saying.
  8. Dec 23, 2009 at 9:10 AM
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    So I tried the sea foam through the Vacuum tube on the brake booster, lots of smoke... drove well for a while. Then turned the truck off, and then back on again and it started to run rough again. It wasnt as bad as before, but still the engine bucked a little. Should I flush more of that stuff through there and just really clean it all out, or maybe go get BG run through it from a shop?
    Dan
  9. Dec 23, 2009 at 9:17 AM
    98tacoma27
    Ben
    Not Beech Creek
    Did they code change when you swapped the coil and wires?
  10. Dec 23, 2009 at 10:44 AM
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    no same code came up, cyl 4 misfire...
  11. Dec 23, 2009 at 10:52 AM
    98tacoma27
    Ben
    Not Beech Creek
    I would suggest getting the compression tested on that cylinder. If you have changed the plugs, wires, swapped coils, etc., then there isn't much left.
  12. Dec 23, 2009 at 12:08 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    im saying ring! if you are hard on acceleration and non of that stuff worked. im saying rings or injector. even possibly messed up valve......................... use injector cleaner
  13. Dec 23, 2009 at 12:51 PM
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    Well I dont have the tools for a compression test, so gotta take it to a shop for that. Would there be any benefit to run the sea foam through the vacuum hose again and really get it clean? And its had 2 injector cleaners run through it so far.
  14. Dec 23, 2009 at 12:58 PM
    98tacoma27
    Ben
    Not Beech Creek
    Another dose of seafoam won't hurt anything. You can usually rent the tester from a parts store.
  15. Dec 24, 2009 at 9:55 AM
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    So trucks doing something else now...
    when I start it to warm it up, it will idle around 2000 rpms, or higher. Then once it gets warmed up and i go drive it, the idle will go up and down repeatedly for a while. This just started happening after the sea foam treatment.
    Dan
  16. Dec 24, 2009 at 10:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    That could be the IAC valve. It will do that if it gets stuck. It is located under the front of the throttle body. Use a toothbrush and carb cleaner to clean it. There are two or three bolts that hold it on.
  17. Dec 24, 2009 at 10:41 AM
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Dont forget to change your oil after you use seafoam as well.
  18. Dec 24, 2009 at 10:47 AM
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    Should the computer be reset as well once all the cleaning is done. And is that just a simple battery disconnect or something more technical?
  19. Dec 24, 2009 at 10:53 AM
    98tacoma27
    Ben
    Not Beech Creek
    It won't hurt to do it. Yes, it's that simple.
  20. Dec 24, 2009 at 10:54 AM
    magnew
    magnew Well-Known Member
    Ft. Collins, CO
    TRD
    I had a 99 6 cylindar. I know there is a TSB for bad head gaskets. I had the same problem. it would run rough for bit then good. I took it to a local dealership and they replaced the head gasket and I also got a new engine out of the deal. It's worth checking out. Good luck
