Truck is running really bad... Misfire...
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99GreenYota, Dec 21, 2009.
  1. Dec 24, 2009 at 10:56 AM
    98tacoma27
    Ben
    Not Beech Creek
    It won't hurt to do it and yes you just remove the NEG BAT cable for a few minutes.
  2. Dec 31, 2009 at 9:18 AM
    99GreenYota
    99GreenYota [OP] Well-Known Member
    Dan
    Devner, CO
    06 Tacoma V6 TRD Sport
    To many to list...
    Well I ended up taking the truck in, the next steps were a little outa my reach... So took it in, they did a compression test on cyl. 4 and it came out fine, and was getting full compression. I'm not sure what that rules out, i'm assuming it would be a bad gasket if it failed, but anyways the next steps are performing a leakdown, pulling valve cover, checking valves/springs/cam/ not to sure, thats why its in the shop. Anyone have any ideas so far after the compression test passed.
    Thanks,
    Dan
  3. Dec 31, 2009 at 9:28 AM
    sflguy4u2
    sflguy4u2 Member
    Pembroke Pines, FL
    10 Prerunner Dbl Cab SR5
    Bed mat.......Chrome Tip....Hard ARE Tonneau cover
    Had same situation on my 03 Tacoma 4cyl. Happened a couple of times and engine light came on....Dealer at first said couldn't get much from the code....Third time went back and the mechanic said it was plugs and could use a fuel injector cleaning. Had them replace the plugs and do the injector cleaning. Never had another problem.
  4. Dec 31, 2009 at 10:16 AM
    98tacoma27
    Ben
    Not Beech Creek
    The compression test would have told you if you had a bad valve seat or possible bad ring. As Steve suggested, the injector may need cleaned.
  5. Dec 31, 2009 at 10:21 AM
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    Great... well as for injector cleaner, its probably had about 3 cleaners run through it. Sea Foam in the tank, the oil, and through the vac line (3 times). I guess the injector could have gone bad, but it should be fairly clean.
  6. Dec 31, 2009 at 10:30 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You've pretty much replaced everything that could be the issue other than the injector. Try replacing the injector and see what happens. You could probably replace the injector by your self.
  7. Dec 31, 2009 at 10:33 AM
    SC4333
    Grant
    FL
  8. Dec 31, 2009 at 11:30 AM
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    I was looking up some symptoms of a clogged injector. My question is why would the truck run fine cold, run fine until i turn it off and then run poorly till the next time it cools down. If an injector was bad or even clogged wouldn't the truck be running bad most of the time, cold or warm...?
  9. Jan 3, 2010 at 5:50 AM
    Air_Ops
    Air_Ops Active Member
    Peter
    N.W. VT
    01 Ltd Dbl Cab
    TRD Headers, Cat Back Exhaust, Airaid Intake Tube, LC Engineering Throttle Body Gasket, Bilstein 5100 Series Shocks, Wheeler's Add-A-Leaf, LC Engineering Tundra Brake Kit, Re-Framed
  10. Jan 3, 2010 at 6:23 PM
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    Never thought about that, something I look into...
    But I picked the truck up today after a week in the shop. Nothing was diagnosed, and they couldn't figure the problem out. Anyone think a toyota shop would be a better idea, or...?
  11. Jan 3, 2010 at 10:35 PM
    2001tacoma4life
    2001tacoma4life 2001tacoma4life
    Tony
    Baton Rouge, LA
    01PreRunner SR5 Off-Road
    3 inch Readlift, line-x spray-n bed liner, spyder black led taillights, euro headlights, 265/75/16 bfgs allterrain, rancho off-raod shocks
    My tacoma did the same thing about three months ago, i got it diagnosed and it was a 4th cylinder miss fire. Changed the spark plugs and coils and that did the trick so i dont have a clue if that didnt work...
  12. Jan 16, 2014 at 8:17 PM
    Prerunnr
    Prerunnr New Member
    99 Prerunner SR5 TRD
    Custom built bumper, cold air intake, diff locker, twin straight pipes car alarms love it
    How did u fix yours or did u ever fix yours? It colds starts fine thn let it sit after it warms up it only runs on five cylinders checked coils plugs and wires new o2 sensor and recently installed cold air in take please help!
  13. Jan 16, 2014 at 8:45 PM
    99GreenYota
    Dan
    Devner, CO
    To many to list...
    I believe it was a fuel injector. Ended up fixing it and about 4 months later bought a new truck.
  14. Jan 17, 2014 at 7:50 PM
    Prerunnr
    Prerunnr New Member
    Everything is eroking fine electrical plugs wires and coils got a new fuel filter boutbto put on wanted to knock the cheap stuff out the way first injector is next tho thanks
