Truck is taken apart right NOW... need help from audio people
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarefootBandit, Nov 27, 2010.
  1. Nov 27, 2010 at 6:37 PM
    BarefootBandit
    BarefootBandit [OP] Well-Known Member
    06 Double-Cab TRD Sport 6-Speed
    delete
  2. Nov 27, 2010 at 6:52 PM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    You can't connect one speaker to two radios/amplifiers.
    When you power on the HAM, the OEM radio sees a short in the speaker system and shuts down.
    Install a seperate speaker for the HAM. Or look into getting a isolation box that allows two inputs to one speaker. Expensive and complicated for the simple setup you want to do.
    Fritz
  3. Nov 27, 2010 at 7:01 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You need a means of switching the wires from the stock radio and the wires from the ham radio so that only one radio is hooked to that speaker at a time. A double pole double throw toggle switch would do the job. Should be able to get one at napa, radioshack, home depot, etc. Just have to route all the wires to the location where you put the switch.
    I've never experienced this myself, but I have been told that most stereos are "smart" enough to shut them selves down if they detect a backfeed into the speaker wires.
    Edit: Using a toggle switch isn't going to work if your goal is to have the stereo cut out automatically when you recieve a radio transmission on your ham radio.
