Truck is turning over but wont start
Discussion in '1st Gen. Tacomas (1995-2004)' started by allison34, Oct 15, 2014.
  1. Oct 15, 2014 at 2:05 PM
    allison34
    allison34 [OP] Member
    96 toyota tacoma sx 2.4 engine
    I have a 96 Tacoma 2.4 engine. this morning I went out to try and start it and it would turn over but it would not start. it ran just fine the day before, I had no problems. I let it sit for a couple hours and then went back out and tried to start it and it was still doing the same thing. Any suggestions?!?!? :)
  2. Oct 15, 2014 at 3:14 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    check your fuses in the dash and under the hood, your coils may not be getting power.
    do you have a distributor? if so take the cap off and check it and test your ignition coil is firing
  3. Oct 16, 2014 at 7:26 PM
    taylorh221
    taylorh221 Member
    taylor
    pikeville ky
    02 tacoma 2.7 4wd 5speed
    if the truck is cranking but wont start and you are getting fire check fuses and if that doesnt showm the problem pull the fuel pump fuse or the fuel injection fuse crank the truck about 8-10seconds put fuse back in and try starting the truck could possibly be flooded
  4. Oct 16, 2014 at 8:22 PM
    keakar
    karl
    louisiana
    also check your engine grounds, a broken or bad connection engine ground wire can kill power to the ignition coils
  5. Oct 30, 2014 at 6:29 PM
    allison34
    we have replaced the fuel pump and the fuel filter and still no luck. the fuel pump is not getting fuel to it...
  6. Oct 30, 2014 at 6:32 PM
    allison34
    we have also checked all the fuses and relays..all are good. the engine is getting spark also
  7. Oct 30, 2014 at 6:55 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Have you checked the fuel pressure at the fuel rail? You can check it before and after the fuel pressure regulator. Not sure what the pressure should be for your truck, but if it's not in a specific range, the injectors won't operate. If you happen to be in the South East PA area, I have a gauge with adapters, but if not, you should have the pressure checked against what it should be to see where your problem lies.
    Edit: Looks like the pressure before the fuel regulator for a 2.4L should be close to 70psi, can't find after the ruglator
    OldGold 96 likes this.
  8. Oct 31, 2014 at 9:32 AM
    keakar
    karl
    louisiana
    if it turns over then confirm the air filter isn't blocked, then there are 3 things to check:
    spark - confirm you get a sprk from each spark plug buy pulling them out and plugging the wires to them, then turn the enginre over and you should see a good blue or white spark from each.
    coils - if you have no spark or the spark is yellow or seams weak it might be bad coils
    gas - make sure you have fuel pressure by cracking loose the fuel line fitting where it exits the fuel rail at the front of the engine and if fuel squirts out your fuel pump and filter is ok. if you aren't sure then trun the engine over for a second to see if fuel squirts out.
    if these 3 things check out then the last thing to check is engine compression.
  9. Nov 1, 2014 at 7:08 PM
    wncjim
    wncjim Active Member
    Western NC
    If you have spark and fuel, check your timing belt. If your engine cranks over normal or a little faster than normal and it sounds like you have less compression, check the timing belt.
  10. Nov 2, 2014 at 4:40 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    he has the 2.4, no belt a chain.
  11. Nov 2, 2014 at 7:04 PM
    97TacoNM
    97TacoNM Riding a 97 Taco
    Jim
    NM
    97 Taco LX 4x4 Ext Cab
    Rampage halogens Custom bed rack
    Check your neutral safety switch.
    http://www.toyotanation.com/forum/1...66549-diy-neutral-safety-switch-cleaning.html
    Also, you can bring your battery to a parts store like AutoZone or OReillys and they can test to make sure the battery has enough juice to crank.
    Do you get a clicking? Flip on your high beams and then try to start - do your lights dim? If the lights do not dim a bit when you are trying to crank over then there is no load being pulled off the battery. This is either a connection issue or the nsw mentioned above.
