Truck jacks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AJ`s Inferno Offroad, Feb 19, 2024.
  1. Feb 19, 2024 at 8:13 AM
    AJ`s Inferno Offroad [OP] 2018 offroad fire ball
    Maryland
    2018 TRD Offroad inferno
    What type truck jacks do you carry besides the OEM one.
    I had a flat and had to change the tire for the first time and the OEM jack was a pain to use. Just curious
    shotgunbilly420 likes this.
  2. Feb 19, 2024 at 8:24 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I only carry the OEM jack. Aside from that, I carry a patch kit. Carrying a heavy jack around for a "what if" moment, doesn't seem worthwhile to me.
  3. Feb 19, 2024 at 8:55 AM
    Maryland
  4. Feb 19, 2024 at 9:02 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    What’s wrong with OEM jack?
    SH10151 and RIX TUX like this.
  5. Feb 19, 2024 at 10:40 AM
    Maryland
    I did up size my tires to 265/70/17 so it may be my fault, I tried jacking up the truck and it seemed like it wouldn’t go any higher and the tire was still touching the ground. So I had to lower the jack and put about 3 inches of wood under the jack to make it work. Plus it takes for ever to use the jack you can only get about half of a turn each time you turn it. But at the end of the day it did work.
  6. Feb 19, 2024 at 10:54 AM
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    Half a turn at a time? You’re putting the hook end in hole thingy on the jack itself then using the tire iron as a crank, right? With all the other links in between? That makes for fast work IME.
    Going up in tire size you should expect the jack to need some help, it was chosen based on stock size/height for everything.
  7. Feb 19, 2024 at 10:57 AM
    saajanpatel1
    saajanpatel1 Well-Known Member
    Saaj
    MA
    2022 Tacoma Limited
    None
    For occasions where i would get a flat tire, the only Jack i have a bottle of Jack, other item i taped to the bottle of Jack is a AAA card
    RIX TUX and Bertw192 like this.
  8. Feb 19, 2024 at 10:58 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Carry a piece or 2 of a 2x6?
    RIX TUX likes this.
  9. Feb 19, 2024 at 10:58 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Did you try to lift it off the frame-rail? The suspension will just sag if you do that
    If lifting the rear, put the jack under the axle. If lifting the front put it under the lower control arm as close to the wheel as possible
  10. Feb 19, 2024 at 11:00 AM
    Bigezee
    Bigezee Well-Known Member
    2013 Toyota Tacoma V6
    Bought my Tacoma 2013, 3 weeks ago and still haven't found the jack. Where is it located? Under the back seats?
  11. Feb 19, 2024 at 11:02 AM
    Maryland
    Mine is under the back seat passenger side
  12. Feb 19, 2024 at 11:07 AM
    Bigezee
    ok, will have to look when I get home. In my Titan I always just carried a floor jack and several pieces of wood.
  13. Feb 19, 2024 at 5:28 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’ve only used the oem jack once when I was belly down on a 8’ pile of mud. I was able to combine it with the rocks and wood and rocks I could find in the area to get myself home. It’s fine in a pinch.
  14. Feb 19, 2024 at 6:03 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    I carry 6 pieces of 2x8 about a foot long. Had some left over from building a deck. Been able to get it jacked up in a ton of shit environments.
  15. Feb 19, 2024 at 6:37 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I use a 3rd gen 4Runner OEM jack with various accessories, doesn't weigh much or take up much space: https://www.tacomaworld.com/posts/29027731
    K9tacoma likes this.
