Truck Jerks When Coming To A Stop
Discussion in '1st Gen. Tacomas (1995-2004)' started by blakeschoonover, Jul 3, 2020.
  1. Jul 3, 2020 at 5:59 PM
    blakeschoonover
    blakeschoonover [OP] Active Member
    Blake
    2003 Silver Tacoma TRD
    Radio
    I have a 2003 Tacoma. When I come to a stop the truck stops hard and kind of jerks (mostly on an incline or decline slope. Today i spent $600 on new rotors, brakes, put more brake fluid, the whole nine yards, and they adjusted my rear drums. After all of that it is still doing it. I have no clue on what this is. If anyone has an idea I would like to hear it. Thanks in advance.
  2. Jul 3, 2020 at 6:01 PM
    Dan 77
    Dan 77 I leave my bikes outside
    Dan
    San Antonio
    06 DCSB TRD Sport 4X4
    Kings and TC UCAS 01 DCSB 4X4 Totaled All-Pro bumper, mile marker winch
    Look up axle wrap with 1st gen Tacomas and see if you are having the same issues. Are your leaf springs original?
    camillethetoy likes this.
  3. Jul 3, 2020 at 6:18 PM
    blakeschoonover
    Blake
    Radio
    yes the leafs are original. The whole truck it self has 91,*** miles on it also.
  4. Jul 3, 2020 at 6:37 PM
    blakeschoonover
    Blake
    Radio
    I looked at some of the forums. I am not too sure it is axle wrap because it only does it when stopping not accelerating. Also for an example I will be in a drive thru and it'll jerk after I move forward only a couple of feet. I have heard it could be the A/C because I do run my A/C pretty much the entire time I drive.
  5. Jul 3, 2020 at 6:40 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    i assume an auto trans........?????????
  6. Jul 3, 2020 at 6:41 PM
    01tacoruben
    01tacoruben Active Member
    Ruben
    Ontario, California
    01 white tacoma extra cab 3.4 manual 4x4
    6inch Fabtech lift. 33 inch tires
    Check to see if you have play in your drive shaft. Possibly the rubber around the support carrier bearing is ripped.(I believe that’s what it is called)
    jammer and camillethetoy like this.
  7. Jul 3, 2020 at 6:47 PM
    blakeschoonover
    Blake
    Radio
    yeah it’s auto.
  8. Jul 3, 2020 at 6:47 PM
    blakeschoonover
    Blake
    Radio
    I got under there and tried to twist the drive shaft and didn’t feel anything.
  9. Jul 3, 2020 at 6:53 PM
    Madjik_Man
    Colorado Front Range
  10. Jul 3, 2020 at 6:56 PM
    ROAD DOG
    FEW
    the auto trans is not gettin signals that U have stopped
    maybe idle set to high
    maybe leak in a vaccum line
    try rollin in neutral b4 U have come to a stop (level ground)
    ( find a vacant shopping center lot !!)
    truck should come to a smooth stop................will elminate the brakes/driveshaft etc
    no less when U put it back into drive
    it might jerk
    it may not
    no less stopped ............... in drive
    take Ur foot off brake
    should move forward (no jerkin) gentle walkin pace
    good luck
  11. Jul 3, 2020 at 7:06 PM
    blakeschoonover
    Blake
    Radio
  12. Jul 3, 2020 at 7:08 PM
    blakeschoonover
    Blake
    Radio
    I’ll check that too thanks.
  13. Jul 3, 2020 at 8:34 PM
    pineapple
    pineapple Well-Known Member
    HAWAII
    2003 Tacoma 2WD
    Could it be.... You are feeling a bump feelIng when you are coming to a stop? Feels like someone Bump you from the rear? Transmission has a delay downshift coming to a stop
  14. Jul 3, 2020 at 8:35 PM
    blakeschoonover
    Blake
    Radio
    Kind of yeah, but it also happens after I just barely move up sometimes without even mashing the gas.
  15. Jul 3, 2020 at 8:53 PM
    camillethetoy
    camillethetoy Just a Minor Threat
    jeremy
    KCMO
    98 T100
    Sounds like the driveshaft issue I had on my 2009, one day I took it in for oil change & they were like oh yeah, we fixed that jerking, there was a recall on the driveshaft, I was stoked
  16. Jul 3, 2020 at 8:55 PM
    blakeschoonover
    Blake
    Radio
    Was it loose?
  17. Jul 3, 2020 at 10:57 PM
    PAIRDICE
    PAIRDICE Active Member
    2002 DC v6 PreRunner TRD Offroad
    Try shifting into neutral before coming to a stop. If this eliminates the jerk then its probably axle wrap.
  18. Jul 4, 2020 at 5:34 AM
    camillethetoy
    jeremy
    KCMO
    98 T100
    I don't know. Back then I was traveling a lot for work & was lucky to make time to even go to the dealership. I knew there was a jerking after stopping but did not try to figure out myself. I was lucky I lived by a good dealership back then.
  19. Jul 4, 2020 at 8:20 AM
    pablotaco
    pablotaco Well-Known Member
    San Diego
    02 PreRunner
    My 02 did this and I greased it through the zerk fitting and it when away for a while but is back. Time to get dirty and do it right.
  20. Jul 4, 2020 at 8:24 AM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    torque converter not unlocking??
