Truck jolts forward after breaking and then accelerating?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lordviews, Dec 27, 2022.
  1. Dec 27, 2022 at 2:19 PM
    lordviews
    lordviews [OP] Well-Known Member
    07 TRD Sport
    When I come to a full stop abruptly mainly all of a sudden then push on the accelerator to go, the truck literally jolts forward as if I’m flooring it skipping a couple gears. Don’t know what it could be. I did a full transmission flush and levels are normal and everything. I even changed out the filter. Don’t know what it could be or if it’s related to it? This doesn’t happen often but when it does, it feels very dangerous as i have to instantly slam the breaks. I have an automatic 07 trd sport.
  2. Dec 27, 2022 at 2:21 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Did it do it before you flushed it
  3. Dec 27, 2022 at 2:23 PM
    lordviews
    07 TRD Sport
    It did not
  4. Dec 27, 2022 at 2:40 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    mmm.You positive the fluid is full?
  5. Dec 27, 2022 at 2:53 PM
    lordviews
    07 TRD Sport
    I have an 07 trd sport. 123k miles. I actually did do a drain and fill. Not a full flush my bad . I checked it by filling it only until there is a small trickle coming out.
  6. Dec 27, 2022 at 3:09 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    whatstcp likes this.
  7. Dec 27, 2022 at 3:41 PM
    FrankTheTank858
    FrankTheTank858 Well-Known Member
    Frank
    Murrieta, CA
    2006 Tacoma DCSB 4WD
    It’s gotta be between 95 and 115 degrees Fahrenheit. It should be trickling out with the engine running.
    Easiest method is to overfill the transmission, idle the truck, then remove the plug until it’s trickling.
    Another way without checking temp is to drain into a pan, let it cool down, then measure how much came out. Then put the same amount back in. Obviously this won’t work for you because you’re past this point but just for future reference if anyone is trying to complete this service.
    cryptolime likes this.
  8. Dec 27, 2022 at 3:47 PM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Try easing the clutch out smoothly, instead of dumping it.
  9. Dec 27, 2022 at 3:48 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    He doesn’t have one of those.
    FrankTheTank858 likes this.
  10. Dec 27, 2022 at 3:50 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    maybe you need to reset the transmission shift point learned values. it probably got used to having a bunch of sludge in there.
  11. Dec 27, 2022 at 3:51 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    This thread has potential. I’m in.
  12. Dec 27, 2022 at 4:22 PM
    lordviews
    07 TRD Sport
    I just got back from autozone with a code that read P2714. Could that be related to the problem I’m having? Or completely different?
  13. Dec 27, 2022 at 4:25 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Could be, it’s a transmission solenoid code. Did you do the fill properly like described in the link? If not you don’t know whether you have too much or too little fluid in the transmission.
  14. Dec 27, 2022 at 6:42 PM
    FrankTheTank858
    Frank
    Murrieta, CA
    Question, was the engine running (idling) when it was trickling out? Or was the engine off?
    if the engine was off, you are most likely WAY under filled
  15. Dec 27, 2022 at 7:50 PM
    lordviews
    07 TRD Sport
    Engine was off. I’ll be adding some first thing in the morning after checking temps. From what I’m reading around and the thread that was posted here about 15 mins idle is close to the right temp?? If not I’ll see if my scanner can read temps as well.
  16. Dec 27, 2022 at 7:53 PM
    FrankTheTank858
    Frank
    Murrieta, CA
    That’s your problem for sure.
    it will trickle out way before it’s at the right level when the engine is off.
    I would put another 3 quarts in at least, start it up and let it idle to the right temp, then pull the overflow plug.
    hopefully a lot will come out, if it does, wait until it trickles.
    if nothing comes out, you need to add more fluid
  17. Dec 27, 2022 at 7:57 PM
    lordviews
    07 TRD Sport
    Thanks man I appreciate it a lot!
  18. Dec 27, 2022 at 7:58 PM
    lordviews
    07 TRD Sport
    I got it straight from the dealer. I only have 1 full bottle left so I would have to purchase more from what it seems like.
  19. Dec 27, 2022 at 8:35 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The resident transmission guru says, “a fast trickle is better than a slow trickle.” :thumbsup:
