Truck jumping.??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Theebrain85, Jul 28, 2024.
  1. Jul 28, 2024 at 1:47 PM
    Theebrain85
    Theebrain85 [OP] Member
    Hello guys picked up this 2001 tacoma crew cab 4x4 auto.. with 144k miles on it about a month ago. First Toyota that I ever bought.Always been a Honda or GMC guy..well to continue with my issue every time the truck jumps to the next gear I get a jolt and it’s very noticeable in low gears at low speeds. Could this be a motor mount issue where the mounts are worn? If someone has experienced similar issues and it’s the mounts are there any particular brand that has a good rep that doesn’t kill the bank?
  2. Jul 28, 2024 at 2:00 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’ll guess center bearing. Go oe.
    Theebrain85[OP] likes this.
  3. Jul 28, 2024 at 2:10 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Driveline "jerking" can certainly point to engine or trans mounts. One mass wants to move and another doesn't. I would look at the trans mounts first as the motor mounts on these are pretty robust.
    Theebrain85[OP] and Black97v6MT like this.
  4. Jul 28, 2024 at 3:18 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Honestly easier to check the mounts than starting a thread
  5. Jul 28, 2024 at 3:23 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Have you checked your ATF fluid level? Sometimes these A340F transmissions will shift hard if they're low on fluid. Otherwise yes, check mounts (engine and trans)
  6. Jul 28, 2024 at 7:07 PM
    Theebrain85
    Fluids good guess it’s time to poke around the mounts
  7. Jul 28, 2024 at 7:12 PM
    Theebrain85
    Honestly haven't poked around the mounts been a hot day.. just curious if anyone has experienced this and its a norm much like the threads I bumped into while searching about this jerking situation which came across about the trucks jumping when shifting cold from park to drive or park to reverse..and seems that it’s a norm with these tacos until they hit regular temp..
