Truck jumps when turning right
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EMTCory, Aug 4, 2022.
  1. Aug 9, 2022 at 9:34 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    MAybe she is like Zoolander and can't turn left. We can not rule it out.
  2. Aug 9, 2022 at 9:34 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    When was the last time you put it in 4wd?
  3. Aug 9, 2022 at 9:39 AM
    EMTCory
    EMTCory [OP] Member
    Cory
    2016 Toyota Tacoma SR5 4x4
    None yet!!
    The tires I am running right now are 10ply. 42 psi is actually lower than the recommended on the tires.
    After reading all the threads to my question, I do have a feeling it is the aggressiveness of the tires.
    I appreciate all the responses to this question. I Love My Taco!!
    TacoPacific likes this.
  4. Aug 9, 2022 at 9:41 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Ok, could be the tires depending on the brand and type. If it hops sometimes the 4x4 vacuum is pissy and can get sticky.
  5. Aug 9, 2022 at 9:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    I've never seen a 'recommended' pressure on a car/truck tire.
    I've seen 'max pressure' on every car/truck tire.
    TacoPacific, Junkhead and Chew like this.
  6. Aug 9, 2022 at 10:09 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I can't say I've ever heard of aggressive tires causing it to bounce...unless in 4wd. I've run beefy Mud terrains and just put some new, pretty aggressive A/Ts on and I've never experienced a bounce.
    I think something else is the cause if you ask me.
  7. Aug 9, 2022 at 10:22 AM
    eurowner
    eurowner Duke Sky
    Scoty
    That's a tad high pressure! Bring em down to 32psi cold and go for a ride.
    TacoPacific and Junkhead like this.
  8. Aug 9, 2022 at 10:24 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I run 235-75-16 10 ply tires on this 7800lb GMC at 40psi cold.
    Junkhead likes this.
  9. Aug 9, 2022 at 10:27 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    What size are your tires? 42psi seems way too much unless you have 35s and carrying extra weight.
  10. Aug 9, 2022 at 12:27 PM
    TacoPacific
    TacoPacific Just a Joe in a Taco
    Vancouver BC
    2021 Tacoma TRD OR DCSB
    Smartcap Evo Sport, Gar-FAB tailgate panel, TRD Performance Suspension/Lift
    I see you told as tire brand/type etc.
    The digging I did as someone else stated; bad Shock or rub due to something unforeseen.
    Have you taken it into anywhere for a look? Would be interesting to hear the result.
  11. Aug 9, 2022 at 1:46 PM
    vnix
    vnix Well-Known Member
    2021 white Tacoma DCSB XP Predator
    blind spot mirrors, center tray, bedrug, more to come
    Anti-lock brake controller maybe thinks a wheel is locking up when it isn't and trying to modulate the brake for that wheel? OP never stated whether braking during the turn (a lot of people do but really should never do that).
    I agree the tire pressure is why too high. I'd bring them down to mid 30s.
