Truck jumps while braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kellydean, Apr 4, 2014.
  1. Apr 4, 2014 at 7:41 AM
    kellydean
    kellydean [OP] New Member
    Keswick,Ontario
    05prerunner
    When I stop at a red light or stop sign I depress the brake peddle and the truck sort of jumps a bit. Any ideas what to check.My truck is and 05 prerunner.
  2. Apr 4, 2014 at 7:46 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    While you are braking? You could be describing axle wrap, but that's usually felt as you take off from a stop more.
  3. Apr 4, 2014 at 7:49 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    And do you feel pulsating on the brake pedal? Maybe a better explanation of what you mean by jumps a bit.
  4. Apr 5, 2014 at 9:31 AM
    kellydean
    Keswick,Ontario
    05prerunner
    Not a pulsation , its hard to describe but when you let off the peddle you feel a little thump in the back end.And what is axle wrap and is it serious.
  5. May 12, 2014 at 5:00 PM
    Bogatzi
    Bogatzi Active Member
    Simcoe, Ontario
    2011 DCLB TRD Sport
    I keep reading about "axle wrap" and would also like to know what it is.
  6. May 12, 2014 at 6:04 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Axle wrap is partly the result of our weaker springs, which Tacomas are notorious for having unfortunately but, I copy and pasted this from another site to save myself all the typing... :
    Axle wrap is a condition that affects vehicles equipped with leaf-type springs under extreme acceleration and, occasionally, deceleration. When the driver of a leaf spring-equipped vehicle applies excessive throttle, the rear axle housing attempts to rotate around the axles as the tires grip the road's surface. The rotation of the axle housing is defined as axle wrap. Under high-traction conditions, the leaf springs will bend as the axle housing rotates around the axle; this bending or wrapping of the springs lends to the term, axle wrap.
  7. May 12, 2014 at 6:07 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Or it could just be the ac condensor kicking on.
    Eitther way not a big deal.
  8. May 12, 2014 at 6:10 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I don't believe that is at all what the OP is describing. But agree, axle wrap is not a big deal.
  9. May 13, 2014 at 10:46 PM
    8675309yine
    8675309yine Member
    Liberty Hill Texas
    06 Taco
    Black Grille, Roll & Lock Bed Cover, Magnaflow muffler, JL Audio 10" in a custom box, Kenwood DNX 6190HD, Pro Comp Xtreme wheels
    I notice it on mine more, when the A/C is on, but it has never bothered me.
  10. May 14, 2014 at 1:14 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Axle wrap. When you brake the axle housing tries to rotate and twists the leaf springs a bit. This energy is stored and the spring. When you let off the brake peddle this energy is released causing the thump.
    Check the leaf spring u bolts and make sure they are torqued upwards of 75 ft lbs or so. If they are your springs may be just getting weak. Nothing to really worry about. I felt it in my 2012 AC, but after I upped the torque on the axle u bolts it went away. I think it is more pronounced on the double cab models.
  11. May 14, 2014 at 2:25 AM
    ducati
    ducati thie-trickster
    Carlsbad, CA
    2013 DC 4x4 Black
    Icon coils, Squeaky dakars, Thule rack, tinted windows, weathertech rain guards, Demello off road front bumper, warn winch, shok sound deadening.
    It's most likely axle wrap. No biggie. Mildly annoying for sure. Usually takes a few bucks to fix it. New leafs would be your best bet.
  12. May 14, 2014 at 6:23 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    to everyone saying 'axle wrap' I doubt it...though this might be true in some cases...
    as long as there is no problem with the propellor, because there is a TSB for 2wd
    T-SB-0250-12: '05-'12 Tacoma: 2WD Rear Propeller Shaft (Driveshaft) Clunk/Thunk Noise
    a few facts about Toyota automatic transmission I have seen on my 4runner
    and tacoma. Note the 4runner has IRS, no leafs and no axle wrap is possible.
    When coming to a stop, and stopping and holding the brake, the internal transmission brakes and clutches pause for a moment before changing to 1st, and this causes an occasional bump-from-behind feeling. My 4runner has done this once in a while, my new Tacoma does this once in a while. It think is normal for Toyota and the way the tranny ecu is set up. since the feeling is identical and the suspension is different...this is why I suggest it is not axle wrap, and normal. ymmv
  13. May 14, 2014 at 9:08 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Yup, I experience the same thing. Was never sure what is was till now.
  14. May 14, 2014 at 10:26 AM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    I've heard that low transmission fluid can cause these symptoms...
  15. May 14, 2014 at 11:03 AM
    JackDaRiffer
    JackDaRiffer Well-Known Member
    Raleigh NC
    2014 V6 PreRunner SR5 DCSB
    Happens to me too in my new 2014 DCSB. First time it happened I thought the car behind me gave me a light tap.
  16. May 14, 2014 at 12:10 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Could be the brake shoes sticking
  17. May 14, 2014 at 1:37 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I agree that some have had this issue, and also some have had the issue with the a/c compressor kicking on and jumping forward.
    But what the OP is describing sounds exactly like axle wrap. He didn't say he's at any point he is "jumping forward".
  18. May 15, 2014 at 5:05 PM
    Bogatzi
    Simcoe, Ontario
    2011 DCLB TRD Sport
    Thanks for the answer Deevon. I wondered why AAL or new springs were often offered as a solution to this problem.
