Truck keeps dying - Please help...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lyneeso, Aug 17, 2017.
  1. Aug 17, 2017 at 2:43 PM
    Lyneeso
    Lyneeso [OP] Member
    Christian
    09 Tacoma PreRunner V6 Automatic
    So here's where I'm at.
    Yesterday I:
    Changed all six spark plugs
    Oil change
    Oil filter
    Air filter
    Took it for a test drive and it drove wonderfully (about 2-3 miles total)
    When I got back home I:
    1. Changed the output shaft seal (it was leaking)
    2. Drained and refilled ATF (did not do ATF level check procedure - but did not drive it - called it a night and went to bed.
    This morning I woke up and went out to put truck into Temp Check mode to check ATF level and I realized that I had left keys in ignition and the battery was dead.
    So, I pulled the battery off my wife's car and put it in my truck.
    Next, I put the truck in Temp Check Mode and let it idle in Park for approximately 10 minutes to allow the ATF to warm up, as I waited for the "AT TEMP" light to come on so I could pull overflow plug and get level right.
    After about 10 minutes of idling the idle got really quiet, about 30 seconds later it just died.
    I restarted it and it fired right up as usual but only ran about 3-5 seconds and died again.
    I started it a third time and gave it some gas and it again ran for a few seconds and died.
    I need to figure out why it's dying and finish the ATF level procedure.... Could it be that I put my wife's battery in it? Did I reset the computer?! When I did the spark plugs I had to disconnect 1 hose. My mechanic friend that was helping me said it wasn't a vacuum line but I just don't know... If it was a vacuum line would the truck have ran well for the test drive?
    The truck has about 1/8 of a tank of gas. The "low gas" light is NOT on... Yet.
    Any ideas much appreciated.
  2. Aug 17, 2017 at 2:50 PM
    devkurf
    devkurf Member at Large
    midwest
    are the battery terminals snug and not loose?
    boogie3478 and outlawtacoma like this.
  3. Aug 17, 2017 at 2:52 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The computer sometimes kills the truck after replacing the battery or putting in one that is good. It's happened to me before multiple times. Keep trying to fire it up and give it some throttle when you get it going. It doesn't sound like anything is wrong.
  4. Aug 17, 2017 at 2:54 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Put some damn gas in it and a new battery.
  5. Aug 17, 2017 at 2:54 PM
    vaya con tacos
    vaya con tacos Well-Known Member
    Have you checked the diagnostics it might be kicking out? Do you have an OBD reader to read the codes?
  6. Aug 17, 2017 at 3:19 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Get your wife's battery out of the car and buy the right one for your truck and go from there...
    JoefromPTC and outlawtacoma like this.
  7. Aug 17, 2017 at 3:22 PM
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    What size is your wife's battery?
  8. Aug 17, 2017 at 3:32 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Getting a bit personal, don't you think....
  9. Aug 17, 2017 at 3:34 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Go get a new battery
  10. Aug 17, 2017 at 4:13 PM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    :rofl:
  11. Aug 17, 2017 at 5:44 PM
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    If your battery died from leaving the keys in it, can't you just jump start it off your wife's battery?
    outlawtacoma and TRDSport10 like this.
  12. Aug 18, 2017 at 5:39 AM
    TexasWhiteIce
    Texas
    How does the truck battery die if the keys are left in it? Never heard of that before
    sioux[QUOTED] likes this.
  13. Aug 18, 2017 at 5:50 AM
    lynyrd3
    Bill
    East Central Upstate NY
    o_O :rofl: :thumbsup:
  14. Aug 18, 2017 at 5:52 AM
    lynyrd3
    Bill
  15. Aug 18, 2017 at 6:50 AM
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    Left in the on position with a light/ radio on
  16. Aug 18, 2017 at 1:49 PM
    TexasWhiteIce
    Texas
    Who does that?
  17. Aug 18, 2017 at 2:17 PM
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    Ain't this Bullying?
  18. Aug 18, 2017 at 2:18 PM
    libagui
    Dominican Republic
    05 tacoma prerunner
    X2
  19. Aug 18, 2017 at 2:18 PM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    The OP:eek:
    TexasWhiteIce[QUOTED] likes this.
  20. Aug 18, 2017 at 2:25 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    I have, in older trucks. The radio wasn't on tho. ;)
